I went out to the garage to start getting the car ready after being off the road for the winter . As far as I can remember I put it away in working condition .... After fitting a new seal and clutch plate / set timing etc. I started the car up . I was wanting the car up to running temp for the timing . The top Rad hose had heat in it but the temp gauge is showing no change after 10 mins of running the engine. The fuel gauge doesn't appear to be working either but I think there is around 6L of fuel in the tank but it doesn't budge from empty on gauge. The rest of the dials / lights / oil pressure are working.
Could these 2 problems be linked ? I'm no good with wiring diagrams.
Has anyone experienced this problem and knows how to go around fixing the problem?
I haven't tested the temp gauge as I have no friends to watch the gauge inside the car.
I know what can cause a temp gauge not to work etc. but I am suspect both problems are amounting from something else.
any ideas ?
The car is a 1967 mk1 dial arrangement .
thanks
