SU Rubber Gasket
970s
SU Rubber Gasket
Post by 970s »
hi, help require ! where can I buy this rubber gaskets ? are they used by the mini?
https://db.tt/I94NsLPA
970s
Re: SU Rubber Gasket
Post by 970s »
sorry!
image not shown!
youngres
Post by youngres »
Swiftune sell something very similar which allows some flex between carb and manifold.
minimans
Post by minimans »
Look's a bit like a webber soft mount?
970s
Post by 970s »
So can we use saft mount on Mini twin SU, may help from leaking issue cause by engine vibration! ;)
pad4
Post by pad4 »
I do believe you can - dint vortz use a similar system to webbers as well
pad
Dr.Mabo
Post by Dr.Mabo »
pad4 wrote:I do believe you can - dint vortz use a similar system to webbers as well
pad
No, not to webers. He did a flexible fixing bolt system for twin HS4. But he claimed this modification would increase the top speed performance of the SUs to the level of Webers.
so long
the doc
so long
the Doc
My previous project:
pad4
Post by pad4 »
Read - he used a system that was similar to whats used on webbers, not he used webbers
i wonder if they did anything ?
pad
wantafaster1
Has thanked: 4 times
Post by wantafaster1 »
Bet it stops the fuel frothing up at high revs.
