Early PD Fuel pump
bubbacluby
Early PD Fuel pump
Post by bubbacluby »
My brother found this sitting in one of his mini's. I told him it looks like a 59 fuel pump.
So its a PD fuel pump. He doesn't know where it came from (we got minis in 61 and didn't have these pumps).
So are these valuable or rare or rebuildable?
I'm thinking it probably came from another vehicle?
It looking pretty sad and is most probably scrap and we will never use it, so it was in the bin
But thought I should enquire before it goes to the local tip.
Thanks Bubba
1959si
Re: Early PD Fuel pump
Post by 1959si »
Hi Bubba, you have a PM.
Many thanks,
Simon
Has thanked: 106 times
Been thanked: 76 times
Don't bin it! :shock:
A PD style fuel pump off the car. This pump was used on all 59 cars.
Scroll Down:
http://1959miniregister.com/variations- ... underbody/
Has thanked: 4 times
Post by Tim »
Can anyone fix them? I have one here that looks almost new, but its stuffed.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
sclemow
Post by sclemow »
You can get a lot of the spares for AUA pumps from Burlen, albeit not a 69 mini one. I suspect the points, rockers, diaphragms etc are the same though.
Simon
Post by Tim »
Maybe, but you can't get inside them as the ends are crimped/rolled over. It might be possible for someone ingenious to open the ends on a lathe, or something.
1955 BSA C11G
1969 Triumph TR6R
Andrew1967
Post by Andrew1967 »
Bubbas one may be unused as I've had a few NOS ones in the past with those black caps on the pipes.
None of the ones I had worked until I cleaned the points up and then they all worked and pumped fuel.
