WTH??!?! Have you seen this item on ebay.
scott6058
Re: WTH??!?! Have you seen this item on ebay.
Post by scott6058 »
YES 120 AND 120+ CLOCKS have a very distinct difference between the two and which cars they were fitted to. And sadly the inners to my 1071 upper right speedo are totally incorrect and sold by one of our fellow posters. Live and learn the rest are authentic but only the face of the 1071/970 120 MPH is authentic. :o
Has thanked: 73 times
Been thanked: 59 times
Nevsmini
Post by Nevsmini »
I like !!!
JC T ONE
Post by JC T ONE »
whats that "thingie" on the bulkhead, next to the airfilter ?
almondgreen
Post by almondgreen »
horn????
youngres
Post by youngres »
It's a Selmar car alarm
JC T ONE
Post by JC T ONE »
youngres wrote:It's a Selmar car alarm
Tupers
Post by Tupers »
I'd rather have the W&P Clubman next to it, or maybe just the doors from it. 8-)
KA2S4
Post by KA2S4 »
scott6058 wrote:YES 120 AND 120+ CLOCKS have a very distinct difference between the two and which cars they were fitted to. And sadly the inners to my 1071 upper right speedo are totally incorrect and sold by one of our fellow posters. Live and learn the rest are authentic but only the face of the 1071/970 120 MPH is authentic. :o
About half the 970s and the early 1275s were fitted with the early speedo.
The graduations on the speedo tell you NOTHING about the size of the motor, (except all 1071s had the early one) the change point was INDEPENDENT of engine size, it was done when they also introduced the voltage stabiliser.
J.
Craig
Post by Craig »
Early Cooper "S" for sale in Florida ....http://www.ebay.com/itm/Austin-Mini-Coo ... ars_Trucks
Has "S" speedo and brakes , wonder what it will fetch ??????
Craig
LDR209H
Post by LDR209H »
They do unearth some amazing cars over there,that looks like the original tub as well. Underside has had some 'reprofiling' and cack repairs but a full mini machine floor would sort that out. The rest looks like a breeze compared to the P38/crusty jobs we're used to. Well spotted.
Pete
Has thanked: 15 times
Been thanked: 34 times
Post by Pete »
Looks like a late '63 1071. :shock: Better nik than this 1275 :
http://nh.craigslist.org/pts/4249056142.html
:shock:
LDR209H
Post by LDR209H »
Pete wrote:Looks like a late '63 1071. :shock: Better nik than this 1275 :
:shock:
Holy moley. At least you'd only need to buy 1/6th of a container to ship it ;)
Nevsmini
Post by Nevsmini »
It's hard to tell if its a cooper or S they shared the same chassis numbers at this time. You would need to see the engine number or Heritage cert to be sure. Looks like the regulator was screwed on to the inner wing! See nylon plugs and screws, they were originally on the bulkhead! Speedo could be a plant! He is not saying it's an S but suggests it in photos ;)
LDR209H
Post by LDR209H »
Nevsmini wrote:It's hard to tell if its a cooper or S they shared the same chassis numbers at this time. You would need to see the engine number or Heritage cert to be sure. Looks like the regulator was screwed on to the inner wing! See nylon plugs and screws, they were originally on the bulkhead! Speedo could be a plant! He is not saying it's an S but suggests it in photos ;)
That was my only reservation Nev,you can't see the hole for the voltage reg through the subframe tab.
All the rest adds up.
Classic Mini electric drive train:
http://www.ebay.co.uk/itm/Classic-mini- ... 4d172919e4
Quote:
"Originally built as an electric drivetrain for the prototype Trend-E electric powered kit car. Comprises an 8 kw electric motor driving a standard mini gearbox through a layshaft onto the clutch. This arrangement allowed for the standard mini pedal and instrumentation layout to be retained. Powered by lead acid batteries giving an output of 72v the vehicle achieved 45mph top speed and a range of 45 miles. the unit is capable of being powered by lithium ion batteries as well.
Drive controls include - Curtis Instruments speed controller & main contactor, main contactors by Machine Electrics and a Zivan NG3 Battery charger. The controls are mounted immediately adjacent to the motor resulting in a compact unit that takes up no more space than a stabdard mini engine. DRIVING IT WAS A HOOT !!!! you could accelerate from a standstill in fourth with no problems and would tow a medium sized caravan so power was no problem."
Mk1 Mini Marcos 1965-1966 barn find unfinished restoration project
http://www.ebay.co.uk/itm/Mk1-Mini-Marc ... 0458884825
