At the moment I have a standard pre a+ 998 and 1128 gearbox with mini remote diff housing in my mk1, which I am hoping to leave complete and sell as a complete unit. Also.....
I have a thin flange 1275 s block and a 480 crank and an austin 1100 1128 gearbox with the close ratio's in it. Also have a 3.44 diff and hardy outputs etc.
I intend to put the close ratio gears (laygear and 1st motion) into a 1128 mini remote diff 1128 box, assuming i can find another one one cheap enough, worst case I will use the one in the car already. Now, are all the 1128 gearboxes the same, i know mk2's had the 1128 fitted with the 1275s, so hopefully i will not in counter any problems there?? I realise the primary gear will be different and I have one of those already.
What is the correct transfer case (clutch housing) and clutch cover for the 1128 box when used with the 1275s, Im not sure of the part number of the ones i have on the car at the moment, once again would like to get another set so i can leave the 998 complete but I need to know what I am trying to buy first.
Thanks Dave
ps. I suppose while I am here any idea on a valuation of the 998 and 1128 box engine complete and just the 998 on its own? I suppose that will give me the best indication on weather to source other parts or use what I have. Recent rebuild (will have covered about 500 miles), no smoke, standard condition and leaded head. Sold in a condition like this without the manifold or carbs.
