In the garage today
JC T ONE
In the garage today
Post by JC T ONE »
Hi all,
Today I pulled myself together, and went to my garage, where the Green Mini Special has been parked since the summer of 2008
I took a 220 volt compressor with me, and a long extension cable.
Found a flat 2 stairs up, where someone would let me borrow a socket, to plug in the compressor.
10 min later, and the wheels had air in them again.
checked oil & water, fitted a charged battery, then turned the engine on the start motor a bit,
without pulling the choke, so she could get some oil around the engine.
Sprayed some startgas into the airfilter, turned the key, and she startet right away.
I then checked if clutch & brakes worked ? and they did
so tomorrow she will be driven to the workshop, for the BIG changes .
Even remembered to make a video http://youtu.be/CZIBNnemI74
Jens Christian
bpirie1000
Re: In the garage today
Post by bpirie1000 »
Well done. Motivation back in full....
Keep it going..
JC T ONE
Post by JC T ONE »
bpirie1000 wrote: Well done. Motivation back in full....
Keep it going..
Thanks , and yes - thats the plan.
More to follow.
