Hello gents,
I was just wondering if there are cranks other than the AEG171 that have a stoke of 68.26mm? An 1100 crank or SA 1100 crank for example...
If so, can they be used in an S block?
I'm sure there was a thread or 2 on one of the old forums about South African 1100 cranks and some engine builds using them. Does anyone have any info or links?
cheers
Tom
1070 vs 1100 cranks
- Vegard
Re: 1070 vs 1100 cranks
My SA crank was measured to 70.2mm stroke.
Pictures here:
http://home.online.no/~lyngset/enginest ... =&pExPic=0;
Pictures here:
Your build was one of the threads I was thinking of Vegard.
It's an excellent thread!
http://www.atfreeforum.com/phpbb/viewto ... um=mk1mark
WARNING: browsing the old forums can be addictive and should only be attempted if you have A LOT of time to spare!
The old forums will be left in place for as long as possible, but as I am not servicing them or paying anything for them they could dissapear at any time. This is beyond my control, so make tghe most of them while you can.
As far as SA1100 cranks V 1070 S ones are concerned. They are very close stroke wise, can fit into an S block using 30 thou thrust washers & seem to be just as good in use as the original S item. They are however getting harder to find even in SA.
