My Mk1 has been fitted with a later front sub frame using single tower bolts. I have had to replace the sub frame (don't ask
The replacement frame is of unknown vintage but I had thought it to be of a similar age.
My problem is that the tower bolt threads appear to be different. The bolts from the circa 1993 Cooper sub frame have a coarse thread whereas the replacement sub frame appears to have finer female threads (3/4 unf?).
Can anyone provide an account of various thread sizes for the single bolt sub frame? Sadly the garage has wound in the bolts before realising they were, ahem, a bit tight and has buggered the threads on the bolts. I am, perhaps in vain, hoping the sub frame threads will chase out with a tap and be useuable again but I need to try and establish what I am likely to have so that I can obtain new bolts and a suitable tap.
Oddly, the usually suppliers only name one type of tower bolt which is said to suit all post 76 cars. My guess is that the coarse threads are metric, although I have not yet done any measurements.
Jon
