11 stud head
wolseley 1000
11 stud head
Post by wolseley 1000 »
Hi all,
I need to drill two extra holes in my 9 stud block to get my 11 stud head fixed
and I can remember there is a description somewhere on my pc how to do it but its gone.
Can anyone help me with some information or experience?
EAVB
Has thanked: 5 times
Re: 11 stud head
Post by EAVB »
I'm sure there will be someone on here who knows better than me but the last one I did I put the head on, spot drilled through the extra holes with a tight fitting drill to get my reference points then, as the engine was in the car, I covered the the entire top of the block in masking tape then used a drill with a mag stand to make sure the stud holes were at 90 degrees to the mating surface. I also shortened the studs on the lathe by a couple of mm and had a quick measure up at the water pump end to make sure that I didn't break through into the water pump recess.
Although I'm not sure if that actually matters as I think the factory drilled blocks just went straight through anyway?
I had a hoover (or Dyson, can't remember) hose alongside the drill to catch as much swarf as possible.
After that I just tapped the holes out, removed the tape, put the studs in, refitted the head etc and drove off sedately down the road!
Probably surfing.
Cornwall, UK.
251 ENG
Re: 11 stud head
Post by 251 ENG »
Perfect way to do it with engine in car :D
Toby
Re: 11 stud head
Post by Toby »
You can otherwise use a head gasket as a template.
T.
Vegard
Re: 11 stud head
Post by Vegard »
I've always used head gaskets as templates. I'd never do it with a hand held drill, this needs to be straight. I've got one 10studded engine due to a not vertical table on a drill :lol:
66S
Re: 11 stud head
Post by 66S »
For this type of operation, I make a tool consisting of a guide tube welded to a foot that is bolted to the block. This tool keeps the drill parallel while you're drilling.
Regards
Re: 11 stud head
I use the first method, more or less identically. Although the crux of the matter is making the hole vertical. Its easy to wander when doing it by hand.
medwaybeat
Re: 11 stud head
Post by medwaybeat »
A well greased drill and tap will help catch the swarf too.
Vegard
Re: 11 stud head
Post by Vegard »
If the engine is in the car I would never attempt this. It'd be much better for you to run the 11 studded head with only 9 studs. You don't need 11.
wolseley 1000
Re: 11 stud head
OK,
my engine is still out so drilling itself is not the problem.
My main concern is that if I break through into the water pump recess the block is not useable any more. Is this so ?
Re: 11 stud head
It is not so, most of the stud drillings in an A series block go into the water jacket.
Just use some thread lock on the stud to seal it.
guru_1071
Re: 11 stud head
Post by guru_1071 »
wolseley 1000 wrote:OK,
you just need to make sure that the stud doesnt go to far through and stop the water pump from turning - i made this mistake on a well skimmed 970 block, i doubt its a problem on a 1275
wolseley 1000
Re: 11 stud head
OK,
thanx all, my head :D feels better now and I think I know what to do next weekend.....
Craig
Re: 11 stud head
Post by Craig »
Make sure and use the correct size drill but .I had a customer years ago attempt this , he used a drill but that "FIT" the holes in the head , then proceeded to drill the block .Yeah the studs fit .............nice and loose !!!!!!
:oops:
Craig
wolseley 1000
Re: 11 stud head
Hi Craig,
have just bought some drills of a friend of mine that works for a specialised company here in Salzburg. They produce these drills and I first couldn´t believe it that they are so expensive. The drills are of a special cobalt HSS material so they sell for EUR 10.- each in a regular shop. The one for the near side of the waterpump is 6.3 mm and the other one is 7.8 mm.
Will do a test drill and tap before ;) .
