engine lifting
mattyguk1
engine lifting
Post by mattyguk1 »
hi all,ive brought a pair of engine lifting brackets. are they designed to fit on the rocker cover studs?
austinisuseless
Re: engine lifting
Post by austinisuseless »
Used to use a a couple of parts made of small pieces of steel high-tensile wire arc-welded onto a couple of old cutdown spark plugs, and they worked brilliantly. Can't remember which plug holes though, must be one and four. Rose the engine out at the right angle - not too much crow barring it out at all.
Think one of Clive Trickeys early books it came from.
coop12g295
Re: engine lifting
Post by coop12g295 »
The brackets fit on the front outer head studs so the diff housing swings away from the bulkhead.Personally I use a Sykes Pickavant engine cradle bracket as it can be altered to lift vertical or on an angle, best £10:00 I spent
YMJ
Re: engine lifting
Post by YMJ »
one L-shaped bracket on the centre head stud.....best 12p I ever spent! ;)
Re: engine lifting
The Sykes Pikavant lifting bracket is one of the best things I ever bought.
M-Machine do a modern version of the same thing.
GraemeC
Re: engine lifting
Post by GraemeC »
On of these?:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
Look to be fetching good money!
I am in the L bracket on centre stud camp - nice and simple. I have the Sykes bracket but have never tried it.
