A proper radius arm shroud for a '59/60
http://www.ebay.co.uk/itm/Classic-mini- ... 337f59fbf6
A proper shape shroud. I'm not sure if and when they changed to the replacements we see now.
- Andrew1967
Re: A proper radius arm shroud for a '59/60
When were the later profiled ones introduced?
I have a NOS early shroud in the garage but not sure if it is correct for my late '60? If it is, I need to find the other side. Better look to see what side it is
Andrew
I have a pair of the early ones knocking around somewhere. One is pretty good, the other will need TLC but will do.
- Andrew1967
I might be interested if my car should have had them. Anyone able to advise ?
Found my NOS one, its the offside.
What is the difference in the early and the later type, cant see it ??
- Andrew1967
The profile is straight where it is shown lying along the table, whereas the later ones are cut with a curved profile.
It's only the underside part thats different.
get a new one and weld a strip of steel,grind off and lightly stopper/hi build prime in to gain the required shape.
much easier than battling with rotted out originals ,
Mike Price of Miniworld from Bilston in the Midlands makes the early radius arm shrouds.
You can find Mike & Glennis at just about every mini show in the UK or tel 01902 353064.
I think there was 3 versions of the mk1 radius arm shouds in all!!!!!!
Chris
Chris
- Andrew1967
Thanks for the ideas Chris and Brook.
Best try to ascertain what my car should have first I suppose.
this shape went upto 1961 on some morrises but ive seen some late 60 austins with the later shape,,,sayin that austin made a lot more cars,so supply dropped quicker
