mk 1 cooper s manifold
stigfried
Post by stigfried »
A friend of mine said there was a posting on here where someone had listed all the mk1 cooper and s manifolds used but i cant seem to find it??? Im looking for twin su and manifold for my s and want to get the right one? I have seen a set on e bay (12A661 P2 MANIFOLD AND AIR BOX) is this the right part number??
any help would be great:)
InimiaD
Re: mk 1 cooper s manifold
Post by InimiaD »
Check out this topic. It should help.
http://www.serifwebresources.com/phpBB2 ... mid=250646
ricardo
Post by ricardo »
I compiled a list to answer a friend and posted it on my blog a few days ago.
http://rsn-mk1.blogspot.pt/
I made a few assumptions based on observation, feel free to discuss!
Pete
Has thanked: 39 times
Been thanked: 105 times
Post by Pete »
I'm after an AEG179 for a 1071 if anyone has one. Also a 12A185 to go with it ! :lol: (missed one on Ebay recently that went for a song ! :oops: )
steve1071
Has thanked: 10 times
Been thanked: 13 times
Post by steve1071 »
Toby
Has thanked: 8 times
Post by Toby »
T.
mk1coopers
Post by mk1coopers »
Wasn't there a thread about there being a 998 and 1071 version of the 12A185?
Toby
Post by Toby »
Here you go, it's on the old forum :
http://www.atfreeforum.com/mk1mark/view ... um=mk1mark
And this one too:
viewtopic.php?f=3&t=1719
T.
ricardo
Post by ricardo »
The one on ebay was the big bore version. Cheap!
http://www.ebay.co.uk/itm/MINI-COOPER-S ... true&rt=nc
Pete
Post by Pete »
mk1coopers wrote:Wasn't there a thread about there being a 998 and 1071 version of the 12A185?
Yes just one look at the huge valves on S version of the 185 distinguish it from the 997 version.The one that went on Ebay was a proper 'S' one , ready to go and cheap. :roll: There's a 997 one on Minimania drilled for 11 studs.
stigfried
Post by stigfried »
thanks for all these pics and id thats great:) but do you know what the P
stands for and do you think the P P1 P2 and all the same inlet angle? eg
cooper S are 20% so do you think the coopers are the same? cheers Ben
ricardo
Post by ricardo »
All have the same angles. 30º IIRC.
Frogeye61
Post by Frogeye61 »
Sprites and Midgets were 20º
Vegard
Post by Vegard »
Pete wrote:There's a 997 one on Minimania drilled for 11 studs.
Is there metal present for such a modification in that type of head?
stigfried
Post by stigfried »
ok thanks so basically your saying all the mini manifolds P P1 P2 997, 1071,1275 all have a 30degree tilt ? so for my 65 austin cooper s it really does not matter which manifold i use as long as it has the two breathers on it(for servo etc ? :)
ricardo
Post by ricardo »
Yes.
For a 65 Cooper S, with servo and PCV, the following will work in standard form:
- 12A661P AEG347
- 12A661P2 AEG347
- AEG573
- 12G2463
The original manifold is AEG347.
You can also modify a Cooper (1004) manifold to take the servo.
stigfried
Post by stigfried »
just what i needed thanks:) thought this looked ok?
http://www.ebay.co.uk/itm/390526100073? ... 1423.l2649
ricardo
Post by ricardo »
It looks like an AEG347 but without asking the seller you'll never know, unless you buy it of course.
The AUD104 stamps indicate Cooper 998, so it could also be a 1004 modified.
Ask the seller for the stamps.
