hello chap
I bought a 1965 cooper s engine this year but it has some carbs on it the i just dont dont what they came off?? so thought i would let you guys have a look?(guru;) the manifold it is on is a osselli but carbs not sure? the numbers on them are AUC 7070 and AUC 7100 and AUC 1323
answer on a post card appreciated
ps not sure if these pics will come out as had to shrink them to load them
mystery Carbs
Re: mystery Carbs
H6 carbs??? Actually are they a mix match? looks like a hiff carb from certain angles actually but with a H carb bowl on the bottom!? Weird..
Re: mystery Carbs
999 ORX wrote:H6 carbs??? Actually are they a mix match? looks like a hiff carb from certain angles actually but with a H carb bowl on the bottom!? Weird..
thanks for that, your right i thought they were a little strange:) they have SU on them ?
- AustinSuperSeven
Re: mystery Carbs
Have a read of this link old chap http://www.mgexperience.net/phorum/read ... 762,page=1
Hope it's of some help
Tally ho
Tally ho
Re: mystery Carbs
They'r HD4 carbs (1,5") as found on the MG Magnette.
They will flow the same as the H4's that ST did offer but the mouting is per HS4, thats why it's mounted on a non BMC manifold.
Re: mystery Carbs
Correct they are HD's.
I have never seen a pair on a Mini, but there is no reason why they shouldn't work fine.
