heater valve
Lilihip
heater valve
Post by Lilihip »
Is this correct heater valve for 1964/1965 Mini 850?
Chalkie
Re: heater valve
Post by Chalkie »
My 64 850 had a heater take off like a later 89 but it had an arm on it :S not got a pic unfortally someone may have a clue on here
Been thanked: 10 times
Re: heater valve
Does that one lean to the left or the right (from the front).
It looks like it is right leaning (towards the R/C) if it is, it won't fit. It needs to lean away from the RC, or at worst be vertical.
Lilihip
Re: heater valve
Post by Lilihip »
I just checked - it is a straight fit. I am looking for original item, most important for me is that it is as it left the factory. originally it should be angled?
Re: heater valve
Yes, originally from the factory it should have been angled away from the R/C.
Dr.Mabo
Been thanked: 46 times
Re: heater valve
Post by Dr.Mabo »
Apart from leaning to one side, the vertical pipe going into the valve from below should have a square shape rather than a round shape. So the valve on the photo is not the version for mk1 minis.
so long
the doc
so long
the Doc
My previous project:
Lilihip
Re: heater valve
Post by Lilihip »
Dr.Mabo wrote:Apart from leaning to one side, the vertical pipe going into the valve from below should have a square shape rather than a round shape. So the valve on the photo is not the version for mk1 minis.
so long
the doc
thanks for that info as well! this is the correct one right?
Dr.Mabo
Re: heater valve
Post by Dr.Mabo »
Jepp, it is.
By the way a very nice engine bay indeed, so always good as a reference.
so long
the doc
so long
the Doc
