Camshafts rust removal!!!!
towners
Post by towners »
Hi
Found a box of these in a recent purchase - quite upsetting!
Quite a few of them are aeg 530 (ST 649 i think) and im certain all of them are/where never used - he had wrapped them in a thin plastic covering
Any ideas on (if I can remove the rust via whatever means) will more importantly will they still be ok to use?
Im in no way an engineer or have an engineering experience!
Your advice kindly appreciated
Paul
Has thanked: 4 times
Been thanked: 17 times
Re: Camshafts rust removal!!!!
Post by Tim »
A professional machine shop could linish them. As long as there is no pitting they'll come up like new. You could do it yourself with very fine wet and dry paper, but if there us any wear on them its probably better to have them done professionally so that they can measure them and tell if they are any good.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
If there's a tiny amount of rust & it hasn't pitted too badly you can probably get away with it. But in my opinion most of the ones illustrated are scrappy dappy doo.
Vegard
Post by Vegard »
I'd have them dipped or bead blasted to remove all the rust. Then you'll easily see if they are pitted or not. If they are, and are not regrinds. then they could be useful cores....
Not what you wanted to hear I guess
Good point, thought about cores & then forgot again.To remove the rust soak them in HCL brick / concrete cleaner for about 20 minutes. Then transfer them into a fairly dilute caustic soda bath. Then dry thoroughly & oil.This will remove all vestiges of rust so they canh be assessed more easily.
towners
Post by towners »
Update spoke with local engineering company and they can polish them with a machine at £10 a hit
I have 3 others in bmc/leyland boxes so 13 in total
I think i will try Marks idea on the worst one first to see what results i get
P
towners
Post by towners »
Mark
Vestiges! you have had your weetabix today!
P
12G940
Post by 12G940 »
Vapour blast them, do not acid them as it will soften the surface hardening, assess the contact area for
consistancy of contact, IE the follower will always be rideing on lets say 80% supported surface area, (that can be an area thats scattered with small pits but still can be bridged at 80%) then they will be ok.
Look at the pitting as an oil entrapment which helps lube the remaining 80%. not the best cams but we can use them.
12G940
Post by 12G940 »
Took another look at your pics and it looks like someone as cleaned/blasted/acid'ed these already before, if so they may already have been damaged beyond salvage.I may be wrong but just check it out before you spend your money.
trevorhp
Has thanked: 11 times
Been thanked: 7 times
Post by trevorhp »
Hi Paul,
What a shame a bit of wd 40 or grease would have prevented this.
If you want to send or bring them to me them to me and pay for the return postage.
I will vapour blast them free of charge and then you can evaluate them more easily.
It only removes the rust !!
Trevor in Taunton Somerset
KDK 320F
HDK 443E
DJJ 226H
TFD 47G
PKV 375
I x 1967 originally Red since 1968 Blue,Ex-Race Cooper S Bodyshell only have Commission plate as ID.
1 x chassis 007 1967 Cox GTM
towners
Post by towners »
Trevor
Have pm'd you
Really appreciate the offer - just another reason why i love this forum, genuine decent people thank you all for you advice
Paul
graham in aus
Post by graham in aus »
Could you show us all the results too!
This is exactly the sort of thing the users of this board are all experiencing, I have a few cams like that too!
Cheers! :mrgreen:
towners
Post by towners »
Will post pic when done
Cheers all
