Purolator Spin On Oil Filter Head - SORTED
Posts are automatically deleted after 6 months.
Rev 2.0 (10.09.2024)
sugarhiccup
Has thanked: 17 times
Post by sugarhiccup »
Hi all,
Looking for a ‘Purolator’ type spin on oil filter head that has the full-sized mating face to the block. I believe these may have been used on Sprite/Midgets at some stage?
Picture for reference:
Postage to Australia or U.K. can be achieved.
Many thanks! :)
CooperTune
Re: Purolator Spin On Oil Filter Head
Post by CooperTune »
You do realize there are two versions. One places the filter further away from the block and transmission. I haven't jigged up one with sub frame in years. I believe there was a sub frame clearance issue with the longer one. I do like the short ones as they have the larger mounting area and threaded steel insert. Steve (CTR)
sugarhiccup
CooperTune wrote: Fri Jan 10, 2025 2:01 pm You do realize there are two versions. One places the filter further away from the block and transmission. I haven't jigged up one with sub frame in years. I believe there was a sub frame clearance issue with the longer one. I do like the short ones as they have the larger mounting area and threaded steel insert. Steve (CTR)
Hi Steve,
Thank you, yes I had read this in another forum thread at some stage. I appreciate you bringing this to my attention again.
I would be looking for the compatible, shorter filter head option that doesn’t have clearance issues.
Cheers :)
Toby
Has thanked: 9 times
Post by Toby »
The part number on the one I have is CAM6684, which hopefully should make it easier to find one
sugarhiccup
Toby wrote: Fri Feb 07, 2025 9:34 am The part number on the one I have is CAM6684, which hopefully should make it easier to find one
Hi Toby,
Thanks for the heads up! I appreciate your message.
They must indeed be very hard to come by, as a google search against this part number yields nothing for me!
Still, I can hold out hope one might turn up…
Cheers mate! :)
Toby
Post by Toby »
The last one I saw for sale was on Facebook marketplace, that sold fairly quick. Have seen them on Ebay too. Good luck with the search!
sugarhiccup
Re: Purolator Spin On Oil Filter Head - SORTED
Managed to finally track one down in the U.S.! It became apparent that they’re definitely not that easy to find…
Thanks for everybody’s help along the way! :D
Has thanked: 90 times
Been thanked: 75 times
One of the best modifications that you can do to your car. No more oil running down your arm and a filter change done in 2 minutes. Paint it and the cannister mid bronze and no one will even notice! Pete the Pom
