The reason the damper valve appears to change position is because there are 4 of them: 2 above, and 2 below the "port plate" to control rebound and bump fluid flow. Their shape varies in the diagrams because they are not symmetrically round and have a different profile depending on viewing angle. See Mini Spares technical article on Hydrolastic units, which contains this photo of the valve (port) plate:Peter Laidler wrote: ↑Tue Mar 11, 2025 10:05 am ....
If you are of a delicate nature regarding the wonderous properties of Hydrolastic, look away now.
It seems as though Dunlop, BMC and BMC publications here at Cowley didn't understand the inner workings of the units either. Take the sectioned drawings illustrated in the previous page, taken from the workshop manual and kindly put up by Martin. Have a look at the part called the 'damper valve'. It should be called 'the MAGICAL damper valve'.
Why is it shaped differently in drawing 1 from drawings 2 and 3. And then...
In drawings 2 and 3, the same damper valve has suddenly, magically by dint of some of its mysterious properties, has been pulled through the metal seating (that it is operating against....., see it?), turned through 180 degrees vertically and re-appeared BELOW the support plate........, upside down!
If you ever chance to remove your units and flush them out, not difficult, have a look at the bits of rusty metal and chunks of rubber that come out with the foul smelling rusty sewage. Those bits that you have shaken out while flushing through are the remains of the rusted out damper valve
Regardless of the state of the damper valves there must be thousands upon thousands of hydro sprung cars (Mini, 1100, 1800) worldwide that are happily cruising the highways today with owners very happy with the ride quality. Anecdotal statements of support for hydro versus rubber cone continue.Peter Laidler wrote: ↑Tue Mar 11, 2025 10:05 amIf you ever chance to remove your units and flush them out, not difficult, have a look at the bits of rusty metal and chunks of rubber that come out with the foul smelling rusty sewage. Those bits that you have shaken out while flushing through are the remains of the rusted out damper valve.
The late John Smidt of the Mini Kingdom fame often would say to me (and no doubt others) that he found within short time, the internal damping would fade and there after, all cars felt like they rode and handled the same. I'm very much inclined to agree with John's remarks.winabbey wrote: ↑Thu Mar 13, 2025 1:44 amRegardless of the state of the damper valves there must be thousands upon thousands of hydro sprung cars (Mini, 1100, 1800) worldwide that are happily cruising the highways today with owners very happy with the ride quality. Anecdotal statements of support for hydro versus rubber cone continue.Peter Laidler wrote: ↑Tue Mar 11, 2025 10:05 amIf you ever chance to remove your units and flush them out, not difficult, have a look at the bits of rusty metal and chunks of rubber that come out with the foul smelling rusty sewage. Those bits that you have shaken out while flushing through are the remains of the rusted out damper valve.
One conclusion from this is that the state of the damper valves is not a major factor in the workings of the hydro suspension.
Hi Peter - these tables are on the BMC Australia displacer engineering drawing AYA4090. Is that the sort of data you are referring to?Peter Laidler wrote: ↑Tue Mar 04, 2025 9:28 amAs for the different stifnesses, all I would ask is this. Has anyone ever seen any reference to ascertain exactly how the stiffness was quantiified by, say, fluid flow or a measure of resistance? Nope, me neither.
If you Google injector socket > https://www.bing.com/images/search?q=in ... C3&first=1 make one out of an old deep socket or even a piece of pipe with a grinder, don't worry to much as 300-400 psi is not really high pressure or you could use an anaerobic ( Loctite ) type of sealer.richardACS wrote: ↑Fri Mar 21, 2025 2:06 pm Thank you Alan re the tape - now ordered..
Thank you Ronnie re thread types - my thread gauge seems accurate for a 9/16 unf 18tpi and this is born out by a compatibility between the actual male thread aligning with the taper lead tap.
Peter re crows foot spanner - I've got a couple of bent ones! There is very little upstand however to create a couple of flats without damaging the rubber and so might just take it very slowly and see if the rubber is strong enough...
Fred (Nippy) suggested using a dowty washer which I have from repair of the Churchill pump...
Time to be brave and see what happens...
Your comment re "decent thickness of metal to hold the new thread" has resonated. The outer dia of the metal tube encased in rubber is 16mm dia, the OD of the male thread is 13.3mm and so to your point a bit of a risk especially if the drill prior to tap is slightly off centre.Peter Laidler wrote: ↑Thu Mar 20, 2025 7:33 pm I am minded to suggest that you turn to page 1 of this thread and have a look at MAB/Martins photo of a sectionalised hydro unit.
Cutting the bonded-in ferrule was a bad move in my opinion. Because you don't have a decent thickness of metal to hold the new thread (and the pressure that the thread is under). That said, it LOOKS like the thread on the new hose is a taper thread that will lock itself as it is tightened. But that is yet another problem because the rubber will want to rotate with the tap as you attempt to tap the thread. And it'll CERTAINLY want to rotate when you try to tighten up the taper thread.
As for drilling/tapping deeper, I think that you are now coming hear to head with the internal valving - that is probably shot-out in any case.
Let us know your further thoughts Richard
Thanks Peter. I'll get on the lathe and complete the tap and die work and get a feel for what I can get away with...Peter Laidler wrote: ↑Sat Mar 22, 2025 12:28 pm Interesting....... Your Q is like a problem that the tutor would throw in to the uni group of students to ponder.
You mention the pinch point dia of the fluid transit point. Without going into the intricacies of the fluid movement, don't forget that the REAL pinch point in the F to R fluid line is the 5mm (?) measure this though) dia hole through the F to R adaptor fixed to the front bulkhead cross member.
So in my opinion, your 6mm guestimate will be fine.
It has been said that the works bushed this adaptor hole to a smaller dia to stiffen the suspension. How true it is I don't know!
Just re-read and digested your thread....... If the i/d of the hydro unit in/out let tube is 6.5mm......... I'm not so sure........ If it were me, in a fix, I'd machine up a slave/dummy 'tube' and see what I could get away with. As Ronnie has said earlier. In the world of hydraulics, 300psi is but nothing and easily sustainable with our thread systems
