cleaning Oil Cooler
- Has thanked: 5 times
- Been thanked: 10 times
cleaning Oil Cooler
I just found a NOS Oil cooler for a Cooper S for 20.-
As the Cooler stayed the last 40 or so years on a shelf, its covered in dust. unfortunately the connections weren't closed so I am a bit concerned about the dust that went inside.
what's your opinions?
-Use it as it is
-flush it and use it
-don`t use it at all
thanks for the replies
-Use it as it is
- Dr.Mabo
- Been thanked: 27 times
Re: cleaning Oil Cooler
hej Doc!
Thank you for your Quick answer!
What would you flush it with?
Brake cleaner, Hot oil, ATF?
- Been thanked: 7 times
Brake cleaner, thinners, petrol - anything that will wash it out well and then evaporate away.
I'd actually be tempted to fill it with your chosen cleaner, seal the ports and leave it for 24hrs to soak. Then flush through.
- Has thanked: 91 times
- Been thanked: 75 times
You can sleep soundly knowing that whatever might be left in the cooler after it's been flushed through with whatever you choose to use will soon be on its way to and filtered by the oil filter
- gs.davies
- Has thanked: 51 times
- Been thanked: 58 times
Apart from when the filter overpressures and bypasses itself..Peter Laidler wrote: ↑Fri Feb 07, 2025 12:56 pm You can sleep soundly knowing that whatever might be left in the cooler after it's been flushed through with whatever you choose to use will soon be on its way to and filtered by the oil filter
My rule is always to replace. There is no way to tell if everything is removed. The repair will cost a lot more than the oil cooler if you get unlucky and miss something.
for this scenario I always block the overpressure valve or use filter heads that don^t have anygs.davies wrote: ↑Fri Feb 07, 2025 1:19 pmApart from when the filter overpressures and bypasses itself..Peter Laidler wrote: ↑Fri Feb 07, 2025 12:56 pm You can sleep soundly knowing that whatever might be left in the cooler after it's been flushed through with whatever you choose to use will soon be on its way to and filtered by the oil filter
I think that we're over complicating this situation. Just flush it through and use it. If you're fretting about the possibility of a blocked filter, just put a new filter on - just to be sure. You could go the whole hog and fit new pipes and..... and..... and.....
You could even pressure test it under water with a cycle pump adaptor if you are still worried. Just use it I say!
- winabbey
- Been thanked: 14 times
How does one ultrasonic clean the oil cooler? What equipment and method is needed?
Equipment needed...Ultrasonic Machine (20lt size), cleaning fluid, water, electricity supply.
Method...Get machine up to desired temp, normally about 55°, but this depends on what cleaning fluid manufacturers recommend, submerge oil cooler in the fluid, set timer to 20 mins, switch on, have a cup of tea whilst the magic happens...DO NOT USE THE WATER OUT OF THE MACHINE TO MAKE THE TEA!
