refitting a carburetor to an MK1 Metro
- Has thanked: 4 times
- Been thanked: 6 times
I cant remember which was the plate fitting on! And the manual dose not show the plate either
Austin Metro MK1 1982 1.3L (same engine and box as the mini)
Re: refitting a carburetor to an MK1 Metro
I though the hock was facing down but the cable mecanisum is in the way
this is what it looks like the other way round
and it can bit between the air bowl and the fdgtrwy coz tis the wrong size
- Been thanked: 9 times
If it helps it's the wrong carb for the manifold. Should be an HIF carb and I presume the manifold has 4 locating holes for the carb stub
The HIF doesn't need the return spring bracket.
![Sad :(](./images/smilies/icon_e_sad.gif)
- Has thanked: 123 times
- Been thanked: 33 times
My HLE MKI Metro has a HIF38 as olddave has mentioned.
The 850 Metro though, did still retain the HS4, though I don't think there was many of these sold in the UK.
The threaded stud on the bracket should be pointing upwards, the air filter bolts to it. Originally your car would have been fitted with a HIF38 carb that used 4 studs to attach it to the manifold.
- 111Robin
- Been thanked: 11 times
Refer back to your original post when you were having issues starting the car, there is a photo showing the carburetor and bracket in situ, stud at the top.
- timmy201
- Been thanked: 18 times
Stud at the top as mentioned above and the throttle cable guide on the LH side of the engine bay
- mab01uk
- Has thanked: 183 times
- Been thanked: 136 times
For reference in the earlier thread on this Metro we found the following info from the engine number:-
12H907AA 136302
12H = 1275cc Transverse
907 = Yd + Bf + Hm + Sk
Yd = Mechanical fuel pump,
Bf = Alternator with negative earth,
Hm = LC8 design variant (probably means the 'Low Compression' A+ derivative of the A-series engine - as in '&' denotes a Mini engine)
Sk = Standard ratio gearbox with 3.44 Final Drive, inboard CV joints and rod change
AA = Carburetter crankcase ventilation and intake air temperature control
The 'Hm' appears to indicate a 'Low compression' A+ derivative of the A-series engine and 'denotes a Mini engine' ?
Which might confirm that this 1982 Metro left the factory with a pre-verto clutch and HS4 SU carburettor Mini spec engine? Although the 1275GT Mini ended production in 1980 and was not low compression....
ie. the Mini spec engine is probably not due to a later engine swap?
viewtopic.php?p=348627#p348627
Hope i have it right nowStopped-again wrote: ↑Tue Jan 21, 2025 8:07 pm The threaded stud on the bracket should be pointing upwards, the air filter bolts to it. Originally your car would have been fitted with a HIF38 carb that used 4 studs to attach it to the manifold.
But I can not remember how it went back together, which cable fits onto which leaver on the carb and i dont remember what the spring attached to
Thanks Martin.mab01uk wrote: ↑Wed Jan 22, 2025 9:56 amFor reference in the earlier thread on this Metro we found the following info from the engine number:-
12H907AA 136302
There was a Low Compression 1275 Metro, these were 8.0:1 Compression ratio and yes, all early Metros had pre-Verto Clutches and were Hydraulic (like mine). They also had Inertia Starter Motors.
All Metros however ere fitted with either a HIF Carb, except for the 850 models.
Here's a page from the factory Workshop Manual covering that engine;-
![Image](https://i.ibb.co/djFgjn2/Mk1-Metro1300-HCLCEngine-Data-copy.jpg)
The throttle cable goes to the linkage nearest the manifold, the one nearest the bulkhead is the choke linkage. Follow your workshop manual to set the “fast idle” position on the choke linkage.
I cant even remember which one was throttle and which one was chokeStopped-again wrote: ↑Wed Jan 22, 2025 8:22 pm The throttle cable goes to the linkage nearest the manifold, the one nearest the bulkhead is the choke linkage. Follow your workshop manual to set the “fast idle” position on the choke linkage.
you say use the manual to set the fast ideal position. What dose that mean? how far do i pull the cable though, or should it be where the kink is in the cable (presuming I have the right cable in that is)Stopped-again wrote: ↑Wed Jan 22, 2025 8:22 pm The throttle cable goes to the linkage nearest the manifold, the one nearest the bulkhead is the choke linkage. Follow your workshop manual to set the “fast idle” position on the choke linkage.
Further more; I cant find where I thread the throttle cable into on the linkarage
- Been thanked: 10 times
Is there someone near to Crackpot who could possibly help him out for an hour? I feel if he is having problems with the cables he will find
setting the fast idle nigh on impossible.Just a suggestion.
