I need to get a replacement vin plate for my 1971 mini cooper S, can someone please confirm this is the correct tag please
Correct vin tag 1971 MK3
- mab01uk
- Has thanked: 183 times
- Been thanked: 136 times
Re: Correct vin tag 1971 MK3
For reference these are some of the range of plates available from Minimail.
![Image](https://i.imgur.com/nfgSiu7.jpg)
Tim of Minimail says:
Quote: "Picture of some of the popular plates that I stock. In time I will list what they refer to but its not a clear cut reference as inevitably, there are some crossovers and there are hundreds of "experts" who will advise elsewhere."
Lots of other useful information on identity plates used on Minis is also listed:-
https://www.minimail.co.uk/chassis-vin-plates/
Thanks for the reply, its all very confusing !
Mine is a 1971 replacement shell ( Lets not go down that route !!) Its a very long story.
But I just need the right age for the shell if that makes sense.
Phib
Phib
It's the same style of chassis plate that my 1972 mini 1000 shell has.
- Been thanked: 6 times
MINIMAIL chassis plates etc - Unfortunately if you Google minimail it will say it is `permanately closed' however is is not the case and if you click `website' on the google you will access Tims site
- CALIMKIIIS
Perhaps it should be the British Leyland one?
"You're not a true petrolhead if you've never owned a mini" - James May 2012 Top Gear
- mab01uk
Logically you would think so, as the Mk3 Mini range had BL badges on the 'A' panels and was introduced just after the BL takeover of BMC in 1968. However it was not unusual for change over points/dates in BMC/BL to not be clear cut, so maybe stock of old BMC chassis plates were being used up in production before new BL plates were issued to the production lines from the stores.
