Wipers
Wipers
Hey all, does anyone have any tips/tricks how to fix wiper splines on mk2 mini without fitting new wiper boxes? Do those splines converters work? The ones that you bolt over the worn out splines? Thanks guys.
Re: Wipers
I was able to find a few wiper arm knurl adapters at a flee market.
Need to check the diameter.
Remove the existing knurl end and replace with adaptor. Tightens on with a hex set screw.
Here is a picture I found on line which is similar to what I bought.
Roger Williams
