AEG312 thin flange Cooper S engine block bored to 60thou. New AE Nural 21251 STD compression pistons size is 60 thou.
AEG177 Conrods, balanced and lightened.
SA 1098cc crank fitted (12G2827 crank) with new bearings 10mains bearings/10 big ends fitted.
22G1128 Remote housing gearbox with 22G1040 gearset. New central oil pickup, baulk rings, 3rd motion bearing, layshaft 2 step, layshaft bearings. 1st motion bearing and needle roller small end bearing. Idler gear bearing replaced in flywheel housing cover (22A524) and 1st motion shaft nose bearing also. 3.44 diff with hardy spicer outputs.
New duplex timing chain kit fitted with new gears.
Cooper S pin drive camshaft, new pin drive oil pump, new cam followers fitted.
12G940 head with 35mm inlet valves, 29mm exhaust valves, new valve guides, new stem seals and valve seats cut and double valve springs. New MS 1.5 Ratio High lift forged rockers fitted.
New welch plugs.
New Cooper S pulley and damper.
New thermostat housing kit, 74 deg thermostat fitted.
New clutch kit fitted.
Video of engine running in my test stand available.
Engine based in pretoria gardens, pretoria, gauteng province, south africa 0082.
Engine can be crated for shipping.
Price R120 000 ZAR or 5 140 GBP negotiable.
Contact Philip +27 72 758 7740 or philip.gates@gmail.com
1275 Cooper S engine
For Sale Section Rules
1) This section is for advertising items that you have for sale. Not for the discussion of listed items. If you wish to debate the pro's & Con's of any item listed, please start a new topic in the appropriate section.
2) Please DO NOT post links to your ebay auctions. This section is NOT for the advertisement of your ebay auctions.
5) Items listed for sale should WHEREVER POSSIBLE* be offered with a purchase price, not asking for bids from members. If you wish to auction your item to the highest bidder I would suggest you use ebay & pay the associated fees.
6) This section is offered as a free service to enthusiasts. Any deals made are between the buyer & seller only. The MK1 forum takes no part in any transaction & the appearance of any item in this section is not a recommendation. I strongly suggest that both buyers & sellers are happy to proceed with a deal before any money or goods change hands.
7) It expected that people posting items for sale are "Active Members of this community". Any Adverts placed by members with a post count lower than 5 will be deleted.
8) The advertising of or soliciting for VIN tags, log books or any other vehicle identification documentation without it's associated vehicle is expressly forbidden. Any member breaking this rule will have his membership terminated with immediate effect.
9) If a moderator considers any postings in this section to violate either the spirit or word of these simple requests the MK1 Forum reserves the right to delete any posts without prior warning or explanation.
10) The posting of items for sale on the MK1 forum constitutes explicit acceptance of these simple rules.
11) Members posting items for sale MUST include a rough location in their profile.
It would be much appreciated if sellers could leave the sale price on adverts after the item has been sold. This acts as a good measure of current value for other sellers.
* In some cases it may not be possible for the seller to list items with a sale price. In this case, listings will be reviewed on a case by case basis by a moderator. The moderators decision will be final.
Gary Davies
(MK1-Forum)
Rev 3.0 (10.09.2024)
Gary Davies
(MK1-Forum)
Re: 1275 Cooper S engine
New Teflon buttons made for wrist pins.
Price reduced.
ZAR110 000 or GBP 4800
I have since been asked the weight of the power unit and have worked on 150kg. Is this correct?
Thanks Philip
Thanks Philip
