Starter switch woes
Aginley
Starter switch woes
Post by Aginley »
So the mini was starting fine ( everything newly built) now I have an ignition light and it won’t start when I turn the key the final part. It starts fine with the solenoid under the bonnet. Question is how do I check the switch is working and also is there anything else I should be checking?
Aginley
Re: Starter switch woes
Post by Aginley »
As a note, I’ve recently installed the interior light and door switches also I’ve moved the starter solenoid onto a period correct bracket
rolesyboy
Has thanked: 5 times
Post by rolesyboy »
Bit of a basic approach but I'd just pull the ignition switch wires off the back of the barrel and short them together and see if it starts.
If it does then your switch is knackered. If it doesn't you need to get a volt meter out and trace
Rolesyboy
Aginley
Post by Aginley »
Problem solved. New bracket was over powder coated and couldn’t earth. Sorted
AndyPen
Has thanked: 7 times
Been thanked: 34 times
Post by AndyPen »
Aginley wrote: Wed Dec 11, 2024 4:09 pm Problem solved. New bracket was over powder coated and couldn’t earth. Sorted
Ah, thanks for letter us know, obvious now you say but easily missed ;-)
