pre made brake lines
ateichert
Post by ateichert »
Best way to straighten (coiled) pre made brake lines(fittings already on).
MagicWandWoody
Has thanked: 15 times
Re: pre made brake lines
Post by MagicWandWoody »
I hold one end down then roll them out on a long bench.
And - recently at least - I also remember to tape the fitting to the tip of the pipe before putting a tight bend near the end.
Tupers
Post by Tupers »
Clamp two pieces of 2x4 together along the 4” face and drill a hole down between the two in the size of your pipe so you have a grove in each piece.
You should then be able to clamp the two pieces in a vice with your unrolled pipe in the middle and pull it back and forth to straighten it.
AndyPen
Has thanked: 7 times
Been thanked: 34 times
Post by AndyPen »
Just wondering what material the brake pipes are and how long are we talking? I did the same trick as Tupers only with some blocks of nylon I had hanging around. I screw mine together and used WD40 to lubricate it all. I also stepped the drilling holes either end after my first attempt - to make it easier to pull and push. As this makes it easy to hold, I could do quite long lengths if I was patient with it.
These day I tend to use the straightener first mind you, as it is so much easier.
Taping the fitting before bending? Now that makes complete sense Magic, why didn't i think of that before ;-)
Has thanked: 38 times
Been thanked: 37 times
And me...... been caught out several times by that oversight, even with home made pipes!
