I'm after a short 60mm manifold for a later type minispares 8 port cylinder head to take 40dcoe weber.
May be interested in swapping a complete Weber induction system for a very well tuned Amal set-up for a small valve head with a fast road cam.
Paul C
Minispares 8 port 60mm weber manifold wanted
Rev 2.0 (10.09.2024)
Re: Minispares 8 port 60mm weber manifold wanted
Have a pair of manifolds . I’ll send you some images ?
I have got a NOS ST ( not Minispares) Amal set up if this helps?
Cheers Paul
Cheers Paul
- Been thanked: 3 times
Why don't you make yourself a nice Maifold like i did? It's not wichcraft...
If you like i can send you a template of mine. The Weber side you can easily download in the World Wide Web...
This way it would more or less easy fit under a standard bonnet
I would appreciate any input thanks!! I have draw 1 myself but wondered if there was second-hand item available.
Can do them for £150 uk post inc.
They are over £400 plus vat from Maniflow.
Regards
Regards
