Door Hinge Free Play Amount
cobolman
Has thanked: 10 times
Post by cobolman »
I'm working on the door of my mini, which has the external hinges.
As I do so, I find that the hinges seem to exhibit quite a lot of free play at the door end of the hinge. Are there any recommendations on the amount of free play there should be?
Thanks.
Cobolman. Conservator for:
Has thanked: 91 times
Been thanked: 67 times
Re: Door Hinge Free Play Amount
This thread below on the 'new door hinge' or 're-bush the originals' options may be of help:-
viewtopic.php?t=22203
Minispares pins and bushes 37H3043 and 37H3044:-
https://www.minispares.com/product/Clas ... H3043.aspx
cobolman
Post by cobolman »
Thanks, mab01uk. I visited the minisport website and ordered some bushes and pins (and a new set of hinges, just in case) :D
Has thanked: 29 times
Been thanked: 30 times
I say, as an engineering type, that there should be NO free play in a properly set of adjusted or rebuilt set of door hinges If there is, they;re wrong
cobolman
Post by cobolman »
Peter Laidler wrote: Wed Nov 06, 2024 7:51 pm I say, as an engineering type, that there should be NO free play in a properly set of adjusted or rebuilt set of door hinges If there is, they;re wrong
Which might explain why mine, one of which has about 10mm free play when measured at the free door end, won't hold the door up enough for me to adjust it properly :lol:
