Sign writing glue remover ideas ?
- Exminiman
- Has thanked: 21 times
- Been thanked: 9 times
Hi Folks
Peeled off some vinyl sign writing, now left with a glue residue in some areas.
Trying to dissolve the glue to avoid endless scraping with a plastic scarper.....so far have tried:
* Thinners
* White spirit
* Methylated spirit
* ZEB sticky stuff glue remover (expensive and hopeless)
Hot air gun - makes it a bit easier to scrape off
Anyone got any ides please - there is a whole high roof, LWB Transit worth to get off
* Thinners
* White spirit
* Methylated spirit
- Exminiman
Re: Sign writing glue remover ideas ?
Thanks, not tried that, maybe the Ethanol will come in useful...
You used to be able to get something called spirit wipe that sparyers used to clean panels, that was quite effective. Frosts do this, no idea how good it is
https://www.frost.co.uk/stripe-off-disc-with-shank/
- johnv
This stuff is really effective
https://uk.rs-online.com/web/p/adhesive ... c7vTUaUAjn
Mk2 1968 Cooper 998 TPL555F
Mk1 1965 Cooper 1275 BFC110C
All good suggestions above.
Acetone might be worth a try; will remove most things, but you may also remove some paint so to be used sparingly
- Joel Welsh 4769VU
Spent some time as a sign installer/fabricator.
Old vinyl can be a bear!
90% isopropyl rubbing alcohol.
Goo gone.
There is a commercial grade adhesive remover for the industry- but it's $65 a gallon!
Acetone will work- but I'd only use after all the sticker vinyl is gone, and you're just fighting adhesive residue.
The rubber wheels are for peeling up the actual vinyl, and don't do much for removing old glue... they work great to heat and smear it though.... and scratch any trapped dirt into your paint.
They're a last resort for me.
Amazon has plastic- single edged razor blades just for this application.
Goo gone.
Wauseon, Ohio- United States
Tartan red and black
I can't take credit for what others built- all I can do is try to put her back on the road.
You just can't fix stupid... you can hide it sometimes though...
- Exminiman
Thanks for suggestions folks, will give them a go and hopefully get this tedious task out of the way
- TECH396
XYLENE Has been a great tool to remove contact adhesive, and safe on vinyl. It all depends on the chemical makeup of your adhesive but I recommend it. Available from most local hardware shops.
Paul H.
- Joel Welsh 4769VU
And actually-
Kerosene!
It's messier- and smells, but it doesn't evaporate quickly like acetone and alcohol.
It will allow you time to let it eat into the glue residue, soften it... so you can scrape and displace it with the soft plastic blade.
More time wiping up a gooey mees with paper towels, and then de-greasing the panels to remove the kerosene... but, effective.
Kerosene!
- Been thanked: 6 times
Citrus solvent? We use it a lot here for removing sticky labels etc. It's usually a combination of limonene and white spirit. It smells lovely and natural, like fresh oranges, but it's actually quite an agressive solvent and will make your skin burn.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
1955 BSA C11G
1969 Triumph TR6R
I’ve always used petrol and lots of rags, test a small area first.
- Has thanked: 7 times
I used to use tar and glue remover made by concept chemicals as a Valeter back in the day, there was an orange citrus smelling version that was quite good too. id leave a rag soaked in it on the residue to soften it a bit before carefully scraping the now jellified glue residue off the paint with a plastic scraper blade. a warm day also helps.
