850 pistons
whistler
Has thanked: 10 times
850 pistons
Post by whistler »
Back in the 60's when I was rebuilding a 997 engine (I think) I was advised to leave off the second oil ring, the one below the gudgeon pin on a 5 ring piston. Have I remembered correctly or was it in a dream?
Has thanked: 59 times
Been thanked: 15 times
Re: 850 pistons
It depends on the ring design and bore (hone) finish, but yes, you usually can leave a ring off.
whistler
Re: 850 pistons
Post by whistler »
Spider wrote: Sat Nov 02, 2024 6:18 pm It depends on the ring design and bore (hone) finish, but yes, you usually can leave a ring off.
Both oil rings are 1 piece ones.
Re: 850 pistons
whistler wrote: Sat Nov 02, 2024 7:01 pm
Ah,,, OK,,, they aren't brilliant at all. I'd run a full set of rings with them. If you wanted to change to a set that had the 3 or 4 piece oil control rings, then sure, leave one off.
