Oil filter housing pipe
Posts are automatically deleted after 6 months.
Rev 2.0 (10.09.2024)
360gts
Been thanked: 20 times
Post by 360gts »
Anyone have a spare one of these....early style with the brass banjo end.
local UK postage.
mk1mad
Re: Oil filter housing pipe
Post by mk1mad »
I have one with filter and oil temp fittings £20
360gts
Post by 360gts »
mk1mad wrote: Sun Oct 20, 2024 12:34 pm I have one with filter and oil temp fittings £20
Thanks for the considerate offer...however, has the wrong 'banjo' end.
mk1mad
Post by mk1mad »
:roll:
Has thanked: 25 times
Been thanked: 29 times
If you are stuck Dermott, it is easy to make another. Just unpick the silver soldered connection on the banjo end and bend a new 3/8" (?) copper or brass pipe to suit. Flare the nut end.
I used a soft soldered joint at the banjo end and it lasted for many months on my S while I had the cooler disconnected and was replacing the filter assembly to screw-on filter spec I gave it away to someone who wanted a shiny one, a couple of months ago
360gts
Post by 360gts »
Still looking>
S33blo
Has thanked: 6 times
Post by S33blo »
360gts wrote: Tue Oct 22, 2024 8:19 pm Still looking>
I offered one but got no response
360gts
Post by 360gts »
S33blo wrote: Tue Oct 22, 2024 10:32 pm
My apologies...I was certain I had replied to you. I have been having issues with my PM's....
S33blo
Post by S33blo »
360gts wrote: Wed Oct 23, 2024 1:29 am
No problem, I’ll try and send you another message. Thanks
