145/70-10 tyres
145/70-10 tyres
Hi, as above which are the best make of tyres for good grip especially in the wet? Nankang jobbies? Or the Falken FK07?
- Has thanked: 7 times
- Been thanked: 6 times
Re: 145/70-10 tyres
Hi
I have Blockley. Wonderfull tyres die good price
MK1 Austin Cooper 998cc 1967 Smoke Grey
http://mk1-forum.net/viewtopic.php?f=6&t=26813
- Has thanked: 131 times
- Been thanked: 111 times
- Pete
- Has thanked: 48 times
- Been thanked: 129 times
Re: 145/70-10 tyres
Don’t forget about the Yoky, decent and a nice looking tyre for a similar price to the Blockley.
https://www.minisport.com/yok1458010y35 ... -tyre.html
The Falkens are not called ditch-finders for nothing!
Re: 145/70-10 tyres
For a good in the wet tyre you only have the option of the Blockley or a Yokohama GT Special unless you want to pay £166 a tyre for the Dunlop Aquajets that are great in the wet and not so great in the dry.
Forget the nasty Falkens and the better but still a bit lethal in the wet Marshals.
I`ve driven the last 19 winters on 10" tyres and the Falkens were by far the worst, even Camacs were a lot better and they were shaped like fifty pence pieces
I`m now using Blockley and when they wear out I`ll be buying them again, nice tyres.
- Minigman
- Has thanked: 10 times
Re: 145/70-10 tyres
Another vote for Blockley from me.
- You must have shot an awful lot of tigers, Sir.
- Yes, I used a machine gun
- Been thanked: 7 times
- r.tec
- Location: Bad Muenstereifel (D), 30km to The Ring, 80km to Francorchamps
- Has thanked: 12 times
Re: 145/70-10 tyres
If you want 70% aspect ratio in 10 inch diameter tyres you H A V E to use 165mm tread width!
- Exminiman
- Has thanked: 52 times
- Been thanked: 51 times
Re: 145/70-10 tyres
New one on me, nice to see some 145s, sensible price as well.Pete wrote: ↑Tue Oct 15, 2024 10:53 pm Don’t forget about the Yoky, decent and a nice looking tyre for a similar price to the Blockley.
The Falkens are not called ditch-finders for nothing!![]()
I have always preferred the handling of road mini on 145s
- gs.davies
- Has thanked: 69 times
- Been thanked: 65 times
Re: 145/70-10 tyres
I'm on the Yokohama GT Classics and have put around 8k on them so far. I'm not particularly keen on them in the wet, mind you, my geometry is well out of whack at the front, so that probably doesn't help.
I'm going to the try the Nankang as they're cheap and my local tyre place can obtain and fit them without any fuss.
Ideally, I want to try the Blockleys but that'll have to wait until I switch the whole car over to 165s I think.
- Has thanked: 35 times
- Been thanked: 49 times
Re: 145/70-10 tyres
Just my opinion the 165 Blockley has a soft sidewall & i needed to up the tyre pressure 32front /28 rear to get sensible road-holding .. not so with the 145 Blockley the sidewall is stiffer & does not have the same issue when fitted on my Moke .
Now need some Snow to try them out.
- Has thanked: 18 times
- Been thanked: 32 times
Re: 145/70-10 tyres
An interesting comment as 145/80 works with 10" wheels but does not with 12" as I discovered when I fitted the regulation Colway remould tyres to compete in the Lombard Revival Rally in an Mpi. Like slippery slicks on the tarmac forest roads in Wales where the pine trees had shed leaves; ice.
Re: 145/70-10 tyres
Interesting observation, anyone else care to share their thoughts on the Yoko GTs in the wet?
