What Do You Do With Frilly Steel?
cobolman
Post by cobolman »
Here's a pic from the inside of my 1960 Austin Seven Mini, showing a front footwell. It's currently painted with some weld through primer as it really shows the frilly nature of the original steel, after it's been blasted to remove rust
That frilly stuff is razor thin in places and it *laughs* at any attempt to be welded.
Much though I'd like to keep the car original, it seems to me that panels like this, especially the floor, are dangerous, apart from anything else. So I wondered how others deal with this.
- Do you replace the panel?
- Continue to patch it but use methods other than MIG?
- Have some other neat approach, like brazing over the affected area?
Thanks for any tips.
Cobolman. Conservator for:
MiNiKiN
Has thanked: 10 times
Been thanked: 7 times
Re: What Do You Do With Frilly Steel?
Post by MiNiKiN »
Whilst I am definitely a proprietor of the "keeper of the OEM panels" group, I would recommend to replace these see-through-steel sections.
Has thanked: 16 times
As Minikign suggests, if it's too thin to weld, it really does need to be replaced.
Having said that, gas welding might be an option or a 'trick' I use often is to put a block of copper behind it and weld away. Find a switchboard builder and get yourself a few copper busbar off cuts.
minibitz
Post by minibitz »
Looking at how pitted the metal is the left of your repair you did amazingly well to get as far as you did without blowing massive holes.
NicholasUpton
Post by NicholasUpton »
In the USA there are people who can metal spray arrears like that and bring them back to new.
woodypup59
Post by woodypup59 »
Surely metal spraying is akin to welding and just as likely to blow holes.
Just cut it out ad replace with new metal.
cobolman
Post by cobolman »
minibitz wrote: Wed Oct 16, 2024 12:52 am Looking at how pitted the metal is the left of your repair you did amazingly well to get as far as you did without blowing massive holes.
Thank you. I was seriously doubting my abilities as I worked on this section :D
cobolman
Post by cobolman »
NicholasUpton wrote: Wed Oct 16, 2024 6:17 am In the USA there are people who can metal spray arrears like that and bring them back to new.
I've never heard of metal spraying. Thanks for the tip
cobolman
Post by cobolman »
Spider wrote: Tue Oct 15, 2024 8:47 pm ... a 'trick' I use often is to put a block of copper behind it and weld away
I've tried this to varying effect. I find that if the floor is really thin, it makes little to no difference. It'll still blow through.
I've also found that I get the best results when the copper backer is held firmly against the steel being welded which, on a floor pan, isn't always possible unless you have clamps with metter long arms :)
I also tried the copper backers with magnets in various places but the magnets never seem to be strong enough for the job.
If I'm doing it wrong, I welcome any advice.
Thanks.
There are limits to what you can do with a copper block, it does need to be hard and tight against the parent metal, but really, if it's that thin, then,,,,,,,,,,
Working with the copper block, you'd be basically using what's there are a guide and 'painting in' new metal from the MIG gun by the sounds of it. Clamp up the block on the side that's more difficult to grind and 'paint away' on the other side.
Has thanked: 4 times
Been thanked: 10 times
To be REALLY honest Cobolman and being a crap-to-useless welder myself, I'd say that just visually, it needs a new floor. Bite the bullet and tell yourself of the old saying, that you can't make a silk purse out of a sows ear.
Just my opinion of course after seeing the material and the comments
cobolman
Post by cobolman »
Spider wrote: Wed Oct 16, 2024 10:52 am ... but really, if it's that thin, then,,,,,,,,,,
I agree, spider. In fact, I'm thinking of writing an article on air welding :D
cobolman
Post by cobolman »
Peter Laidler wrote: Wed Oct 16, 2024 11:27 am I'd say that just visually, it needs a new floor.
Thanks, Peter.
I hesitated only because the replacement floors I found didn't match the original footwell depression shape. It's a distinct pattern unique to late 1959 / late1960 Minis, sometimes referred to as an 'interim' style. It was only used for one year of manufacture.
But following a lead from the forum admin gs.davies, I went to the 1959 Register and thence to a chap called Dave at Phoenix Motor Bodies. He tells me he may have some panels. I've got my fingers crossed!
Wherever I can, I am trying to keep the car original. When I can't, I'm striving to make it look original. In some ways it's daft because the following panels are new:
- Outer wings
- Front panel
- Boot floor
- Outer Apex Panels
- Rear quarter wings
- Wheel arches
There are a number of patch panels in place too (boot hinge, boot lower sections ...)
Where these new panels deviate from the original style, I make adjustments.
For example, the boot floor. I'll weld metal over the holes cut for fog lamp wiring and patch the large oval hole for fuel injection cars, with the two hole original floor part.
I don't want to end up with triggers broom but I also don't want the car to fall apart because it's unsafe.
I never expected that I would spend so much time weighing the options to keep the car looking right.
In many ways, knowing what I know now, I wish I'd bought a later Mk1 car. Much easier to keep looking original. Maybe next time? :)
68Deluxe
Has thanked: 9 times
Post by 68Deluxe »
cobolman wrote: Wed Oct 16, 2024 10:27 am
Thanks.
Hold your copper up with a trolley jack.
cobolman
Post by cobolman »
68Deluxe wrote: Thu Oct 17, 2024 5:56 am Hold your copper up with a trolley jack.
I like that idea, thanks! Not sure it'll go high enough for me though as the car is on a rotisserie.
Nick W
Post by Nick W »
Thin rusty metal is easier to weld using C02 rather than Argon. But looking at the panel you have I'd replace it to be honest.
I have a hole in my copper block so I can screw it in place when necessary
Up North in Sheffield
Tupers
Post by Tupers »
As much as I like to save original panels I think that floor is too far gone especially on a monocoque car.
68Deluxe
Post by 68Deluxe »
cobolman wrote: Thu Oct 17, 2024 8:52 am
Can always use a lump of wood to take up some distance :)
