Compression ratio / pistons needed
swifty
Post by swifty »
Hi could the clever among you advise on piston cc needed . Block is 1275 + 40 bore . Want to use a race head that has 16.4 cc . So what cc do I need in the pistons for approx 10.1 compression ratio
1963 austin Cooper s mk1 1071
1966 Austin Cooper s mk1 1275
1968 Austin Cooper mk2 998
1962 Morris mini super 850
Porsche 997 turbo S
Ford transit van 280s.
I am from Essex
hanlminiman
Has thanked: 4 times
Re: Compression ratio / pistons needed
Post by hanlminiman »
Now that is "techinical talk!" :lol:
rnp68
Post by rnp68 »
from my rough calcs assuming a 40 thou deck height and a 3.4cc gasket you will need 12cc dished pistons.
timmy201
Post by timmy201 »
There’s a compression ratio calculator that will give you an approximate number here. It might be tricky to correct the compression ratio with such small combustion chambers
https://www.classicminidiy.com/technical/compression
abs
Post by abs »
If you are using a wild cam to go with the race head you will need to work out the dynamic CR in which case your static CR would be able to be higher.
It`s way above my head but hopefully someone like Spider will be along soon.
You can have a little material machined from the piston crowns as well if needed.
swifty
Post by swifty »
That ratio calculator is great . Will probably go for omega 10cc pistons … thanks for reply’s … Shirley
Porsche 997 turbo S
I am from Essex
wantafaster1
Post by wantafaster1 »
Depends on the cam you want to use
