Cooper S Core plug sealant
Hi, can anyone help ?
Ive just recently done a full rebuild of my engine and had the block acid dipped, hence all the core plugs were removed,
Fitted the core plugs but now they all leak, even if the engine hasnt been started.
I now have to remove all (4) core plugs and replace them.
They were all the correct size, 41.4mm
Does anyone know what the best sealant is so that they dont leak again ?
Thank you.
Roland
Thank you.
Roland
- Has thanked: 66 times
- Been thanked: 63 times
Re: Cooper S Core plug sealant
I blame brexit for the leaks Roly!!!!! When I did mine the machine shop in Oxford told me to re-seat them using that really thick creamy white gluey stuff used by gas fitters when they cap-off the threaded gas pipes in your house. Did mine by smearing it round the plugs and in the holes and they ain't leaked since the late 80's............ Not even when I changed to waterless!
- Been thanked: 3 times
I think I used a smear of Loctite thread sealant (not threadlock) - think it was 567 off the top of my head
- johnv
this stuff, Roland
https://www.ebay.co.uk/itm/133101975741 ... 3yEALw_wcB
I have some here if you're in a hurry!
Mk2 1968 Cooper 998 TPL555F
Mk1 1965 Cooper 1275 BFC110C
- Has thanked: 123 times
- Been thanked: 34 times
I've only ever used Loctite 243. Yes, it's a thread locker, but it's also a sealant.
- MiNiKiN
- Has thanked: 39 times
- Been thanked: 17 times
My weapon of choice for any such application is Loctite 620. It has a greater gap-filling ability than the others.
https://www.henkel-adhesives.com/uk/en/ ... _6200.html
Yes I am a nerd: I am researching the Austrian Mini-racing scene of the 60s and 70s ![Uber Geek :ugeek:](./images/smilies/icon_e_ugeek.gif)
Just as important as the sealer, prepping the opening goes a long way toward proper installation. Steve (CTR)
- TECH396
Message deleted
Message deleted
Message deleted
- Ronnie
- Has thanked: 5 times
- Been thanked: 19 times
Any quality jointing paste or anaerobic sealer should suffice if the surface is clean and in sound condition, if they leak (which they shouldn't) you could attempt to peen them in. ![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
Deleted
