flywheel end main bearing question
BAD942B
Post by BAD942B »
A quick question, on the centre & timing case main bearings the 8mm oil drilling goes straight into the main 10mm transverse oil gallery, on the flywheel end main bearing the oil drilling goes in about 3"then stops about an inch from the gallery, spraying brake cleaner down the oil drilling proves that oil gets to the transverse oil gallery, (this is the block that did about 21.5k of very hard miles in my ownership) is there a restrictor with a tiny hole in it down there. Same on my 'new' block. is this because there isn't a cam oil feed from the main bearing like the front 2
Just asking
Chris A
imack
Re: flywheel end main bearing question
Post by imack »
The ' blockage' is the oil pressure relief valve seat. Oil flows from the main gallery, around the seat and the to the main bearing.
Somewhere online there's a picture of a sectioned a series block showing the oil path at the relief valve end of the block. It shows how the 'waisted' relief valve seat allows oil flow to the main bearing.
I've not been able to find the picture.
BAD942B
Post by BAD942B »
imack wrote: Tue Aug 13, 2024 6:17 pm The ' blockage' is the oil pressure relief valve seat. Oil flows from the main gallery, around the seat and the to the main bearing.
then they must have machined an anulus then pressed in the OPRV seat afterwards
Chris A
BAD942B
Post by BAD942B »
I wondered how they got round the OPRV drilling, hadn't thought of that
Chris A
1071bob
Been thanked: 52 times
Post by 1071bob »
This one? You can remove the PRV seat with with a threaded rod.
BAD942B
Post by BAD942B »
even cleverer
Chris A
BAD942B
Post by BAD942B »
looks like the seat is pressed in to a depth rather than up against the step
Chris A
imack
Post by imack »
1071bob wrote: Tue Aug 13, 2024 8:12 pm This one? You can remove the PRV seat with with a threaded rod.
Yes, that's the one I was looking for.
Has thanked: 126 times
Been thanked: 105 times
Sectionalised things like that block reminds me of the stuff that we used to sectionise as 60's era engineering apprentices. Usually a group of 5 or so would be given a task to discuss what was needed, how and to get on with it!
A lot of these examples of past apprentices work was on display in the training schools or presented to visiting dignitaries...... Alas, none of my groups work met with such acclaim. After being marked, it probably went into the scrap
I wonder of they do it now........ Maybe not!
Has thanked: 173 times
Been thanked: 58 times
I always pull the seat before sending the blocks out for cleaning and machining and only re-fit them after the final shop cleaning. There's no other way to clean that end of the block.
MiNiKiN
Has thanked: 76 times
Been thanked: 30 times
Post by MiNiKiN »
The obvious question to follow: what is the thread size? 5/16 UNF maybe?
GraemeC
Been thanked: 7 times
Post by GraemeC »
Whatever you make it - its not threaded to begin with
BAD942B
Post by BAD942B »
MiNiKiN wrote: Wed Aug 14, 2024 7:57 am
far bigger than that, bore size is originally around 8mm but as Graeme says its not threaded to start with
Chris A
BAD942B
Post by BAD942B »
I guess the real question is can you buy them
Chris A
BAD942B
Post by BAD942B »
MiniSpares list them 2A797
Chris A
MiNiKiN
Post by MiNiKiN »
I lost control of my life - CUT! - parts stock I mean of course. :roll:
I just recently bought this along with a new oil pressure release valve (read: not ball)
I tap them 3/8" UNC and use a head stud and a socket as a spacer to pull them.
BAD942B wrote: Wed Aug 14, 2024 10:52 am I guess the real question is can you buy them
999 times out of 1000 I reuse them.
