Gaskets
Jasonking
Gaskets
Post by Jasonking »
Can somebody tell me in which order the gaskets, spacer and abutment plate fit please, from the manifold up to the carb?
Has thanked: 123 times
Been thanked: 102 times
Re: Gaskets
Mine is this. Inlet man, gasket, heat shield, gasket, spacer, gasket carb body.
There was a bit of a discussion about it a year or so ago and someone suggested that the spacer should come before the heat shield. But as long as the extended heat shield doesn't touch the exhaust, does its job and the cross-bar holds the carb springs correctly in line with the carb levers, I don't think that it matters too much either way
Jasonking
Re: Gaskets
Post by Jasonking »
Ta Peter, by heat shield you mean the abutment plate that holds the cables?
Re: Gaskets
By heat shields, I mean the two large cranked steel sheets as shown in the parts list, 12A 219 and 247
GraemeC
Been thanked: 7 times
Re: Gaskets
Post by GraemeC »
Jason - what carb(s)?
Presumably as you’re talking about abutment plates they’re HIF types? In which case you may need the spacer between the inlet manifold and the play to stop the mechanism fouling on the exh manifold
Jasonking
Re: Gaskets
Post by Jasonking »
Oops sorry, std 850 1.25” HS2
timmy201
Been thanked: 34 times
Re: Gaskets
Post by timmy201 »
Mine was:
Manifold
Spacer
Abutment plate
Carb
With gaskets in between all the layers (do yourself a favour and order at least 10 and keep them somewhere safe)
Re: Gaskets
There....... a good example of the need to give a full explanation of the problem Jason. Being a mini cooper orientated forum, we're expecting, wrongly, standard twin SU's of some sort
Jasonking
Re: Gaskets
Post by Jasonking »
I’d be happy enough to get one SU working properly at this point! Which way up does the manifold gasket fit on the head?
Jasonking
Re: Gaskets
Post by Jasonking »
My apologies guy’s didn’t realise you all had Coopers, soz😊
GraemeC
Re: Gaskets
Post by GraemeC »
We don't. I don't think the forum is orientated primarily to them at all, far from it.
But Peter's comment about giving all the info does help people give answers to your questions that are more likely to be applicable.
Has thanked: 4 times
Been thanked: 19 times
Re: Gaskets
Post by Tim »
Jasonking wrote: Sun Jul 14, 2024 6:49 pm Which way up does the manifold gasket fit on the head?
The original style is more or less symmetrical, so I don'tthink it matters. If it has a metal side, that goes towards the manifold.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
Jasonking
Re: Gaskets
Post by Jasonking »
Thanks everyone 😀
