I hate my mini!
I hate my mini!
Rebuilt top end(again) fresh skim on head, composite gasket everything to the book, now it won’t bleeding start! I’m losing the will to live
- woodypup59
- Been thanked: 13 times
- Rolandino
Re: I hate my mini!
Nooo! Never hate your mini, it's just a bit sore. For it, it's like you going to the dentist. Check plugs, points conderser spark and petrol. Timing wasn't changed, so it will go , eventually
I hate electric cars !
- Rolandino
Re: I hate my mini!
xxxxx
Re: I hate my mini!
Just work through the process.
Do you have fuel where it needs to me and in the correct quantity? You can start a car on ezi start or brake cleaner. This will prove if it's fuel related
Next, the sparks. Are they happening? Remove a plug and turn over the engine with someone holding the plug against the block. You should see it sparking. If not, then there's something wrong.
Have you had the dizzy drive out? It's really easy to get the drive 180 degrees out (my 18 year old self will tell you this).
Getting the inlet manifold seated correctly is harder than it should be as you can't see if it's in the correct position.
It's a challenge, you'll solve it, we've all been there.
- BAD942B
Re: I hate my mini!
has it been standing for some time or overheated before the head came off ?
put one pump of oil down each plug hole from your oil can, crank it over with the plugs out & try again
Chris A
- Been thanked: 17 times
- Has thanked: 27 times
- Been thanked: 29 times
Re: I hate my mini!
Sadly, the trouble is with you Jason. You have given the forumers the archetypal '.....my car won't start. What's up"?. You haven't told us the whole story.
It only needs three things, in the right order and in the right amounts. A bit of petrol, a bit of air and something to set fire to the mix. Let us have a bit more info and your prayers will definitely be answered
Re: I hate my mini!
Plugs are sparking, not touched dizzy since refitting rebuilt jobby from Dizzy Doctor, fuel is few weeks old and is getting to float bowl, it ran briefly but manifold gasket was leaking badly, would that be the problem? Weak mixture/air leaks?
Re: I hate my mini!
might be a stupid question. but!!! have you checked the tappet gaps after refitting the head ?
Re: I hate my mini!
Yep, tappets all done, only difference from last time is leaking manifold gasket?
Re: I hate my mini!
You say that it has run briefly..... Briefly for how long? Distributor. Has it run with the rebuilt distributor and have you set the dist manually first?
I suspect that it's 'out of spark' timing And fuel in the fuel bowls doesn't mean fuel to the jets if there's crap in the fuel bowls. Suck them both clear with a vacuum cleaner and set the ignition timing manually to start with
Frustratingly been there with both of the above. If you lived near here, we'd have that started and running nicely just in time for a beer at The Black Horse at lunch time!
- Exminiman
- Has thanked: 21 times
- Been thanked: 9 times
- woodypup59
Re: I hate my mini!
It ran for 20-30 seconds this time, but has run/ticked over well since fitting dizzy and settling timing via the little port in flywheel cover, unfortunately leaking head gasket got in way of further running
Re: I hate my mini!
Manifold leaking is a big reason why it will not run.
I was also going to add a blocked jet. I had one on a rebuild, the engine would fire but not run.
Re: I hate my mini!
Thanks for all your support/suggestions, will check carb tomorrow, manifold gasket is totally knackered! Carb gaskets are very wet with petrol, guess should’ve replaced them too
Re: I hate my mini!
I never knew about the little collar to set the carbs to inlet together...actually cost me a trip on a flatbed..
Re: I hate my mini!
Tried today to reset points and set timing but no different just turns on starter but no firing, im obviously doing something basic wrong, but for the life of me can’t get me head round what it is Last time I fiddled with points was 1977!
- woodypup59
