Ever Seen Welds Like This?
cobolman
Has thanked: 10 times
Post by cobolman »
I bought a Mini that was described as "All bodywork done - just needs finishing" That has not turned out to be the case and the more I dig, the more problems I find.
I'd welcome your thoughts on the following welds which had been done by the vendor before I bought the car. They attach a new heritage wing to the original inner wing. It's the same on the other side. It's a similar story on the seam for the A panels.
Cobolman. Conservator for:
mini_surfari
Re: Ever Seen Welds Like This?
Post by mini_surfari »
That certainly is a bit of a mess.
Personally if the wings are the only parts with such poor welding, I'd cut them off and start again. But makes you wonder about the rest of the work that's been carried out!
If its solid though, and you can live with it, you could just grind it down nicely and seam seal in the channel.
Although I'd imagine the metal getting thin in places.
atm92484
Post by atm92484 »
I hope the apprentice did those.....
If the panel gaps are good, I'd sand the welds flush with a bandfile sander, touch up welds as needed, sand again, and seam seal.
Exminiman
Has thanked: 21 times
Been thanked: 9 times
Post by Exminiman »
cant quite see, but is the wing out of line with the scuttle ?
Scuttle also looks bit bent, as if a repair end has been mis aligned.....?
Might be the photo though, lets hope so...
cobolman
Post by cobolman »
Exminiman wrote: Thu Jun 27, 2024 1:36 pm cant quite see, but is the wing out of line with the scuttle ?
You nailed it. The wing is indeed out of line. The scuttle closer panel is poorly attached. I have to consider taking the whole front end off and re-doing from the scuttle area forward. I hope I can save the inner wings, but the front parts seem in poorly repaired condition:
Also, the front wings and front panel, though new, seem in very poor shape.
It's all the more annoying as the car was sold as "Major work done. Just needs paint and interior re-fitting" (para-phrasing - but that's the gist of it)
Exminiman
Post by Exminiman »
It might be easier to look at what is good, hopefully roof, bulk head, back panel ..and price up for a replacement full floor inc boot, wings, quarters front panel etc…..to see if it worth it.
In the end, most end up replacing all the floors and front end these days anyway…just annoying if that wasn’t a road you thought you had to go down……
Has thanked: 86 times
Been thanked: 63 times
Exminiman wrote: Sat Jun 29, 2024 10:21 pm It might be easier to look at what is good, hopefully roof, bulk head, back panel ..and price up for a replacement full floor inc boot, wings, quarters front panel etc…..to see if it worth it.
Front end replacement of wings, inner wings, front panel, maybe due to the poor welding and alignment....but I don't agree that a full floor/boot replacement is required based on the previous posts, especially as this an early shell with the original flat unvented sills and floor in reasonable condition.
Exminiman
Post by Exminiman »
mab01uk wrote: Sun Jun 30, 2024 9:25 am
Front end replacement of wings, inner wings, front panel, maybe....but I don't agree with a full floor/boot replacement is required based on the previous posts, especially as this an early flat sill Mini.
Appreciate where you are coming from, but is the heel board intact, the boot floor is also too much of a mess to save.
Also have to bear in mind that most early '59/60 Minis even in mint original condition currently have a market/insurance value of approx £15-20k and don't achieve the higher levels of Mk1 Cooper/Cooper S selling prices, so unless money is no object (or the Bangers & Cash team do the restoration!) have to be done on a tighter sensible budget. It is also nice wherever possible to know that the majority of the cars bodyshell is what originally left the factory back in the day rather than becoming another 'Triggers Broom'. :lol:
68&86auto
Post by 68&86auto »
Yes I've seen welds like that.
As you've found out,
is NEVER the case. If it was then it would be finished already. There's various reasons for this to be the case. If they ran out of money to paint it then they probably didn't have enough money to do the work they have done properly either. Someone who knows what they are doing (properly) will have a good idea what it's going to take to finish including labour and cost when they start a project. If they do abandon the project, anyone honest isn't going to say it's ready because it won't be. That leaves the people who don't know what they are doing...
The same story with going cars, if it doesn't need much work then it wouldn't usually be sold.
I buy the cheapest cars assuming nothing is good.
mullerm
Post by mullerm »
In my part of the country its call "Bird shit welding "
rpb203
Post by rpb203 »
I’d forget the bird, to me it looks like it is just shit welding.
Sorry.
Fanfaniracing
Post by Fanfaniracing »
I've really seen wors than that. Most on very expensive famous cars...
