Being just about to start some welding, I know that I need to get the surfaces bright and clean before I begin.
But then I read about weld-through primer. Is this a good idea?
Once a section has been welded and linished, I'm guessing the repaired area would benefit from primer. But should I use a simple primer? Primer filler? Or some other type of filler?
My current plan is for the car to be finished using cellulose paint. Should I be using a specific primer for that?
In summary: Any advice on which paints I should be using as I go through and try to patch the bodywork?
What Paints Do You Use?
- MiNiKiN
- Has thanked: 17 times
- Been thanked: 9 times
Re: What Paints Do You Use?
Weld through primer or zinc spray where you have overlaps is certainly better than nothing between the two layers.
Once welded I apply etch primer from a spray can to avoid the immediate flush rust that'll otherwise apear.
When everything is welded, ground back and panels straightened I'd apply an epoxy primer.
I have no clue about cellulose paint...
- r.tec
- Location: Bad Muenstereifel (D), 30km to The Ring, 80km to Francorchamps
- Has thanked: 7 times
- Been thanked: 3 times
Hi there, I used to utilize Caropax with which I had good results especially with MIG spotwelding. Caropax is not any more availlable so I tried EUROPAX which obviously superseded Caropax with equally good results.
I do not know if this paste is availlable in UK and perhaps some of UK citizens are a bit allergic against the name of the product.
- Has thanked: 27 times
- Been thanked: 29 times
We seem to be dishing out all this good helpful advice to Cobolman. But unless we know where in the world he is, we are really urinating into the wind.
Tell us where you are Cobolman!
- cobolman
- Has thanked: 10 times
You're absolutely right about the excellent advice on here Peter and thank you to all of you.
I'm based in Devon in the south-west of the UK. Fairly close to Plymouth, in fact.
Cobolman. Conservator for:
- cobolman
Great advice. Thank you!MiNiKiN wrote: ↑Fri Jun 28, 2024 8:20 am Weld through primer or zinc spray where you have overlaps is certainly better than nothing between the two layers.
- cobolman
LOL! I'm very Euro friendly so thanks for the tip!r.tec wrote: ↑Fri Jun 28, 2024 9:00 am Hi there, I used to utilize Caropax with which I had good results especially with MIG spotwelding. Caropax is not any more availlable so I tried EUROPAX which obviously superseded Caropax with equally good results.
