Sliding window frame question...
Does the window frame sit on some kind of mastic on the door top?
Any advice gratefully received
- Has thanked: 27 times
- Been thanked: 29 times
Re: Sliding window frame question...
It sits in 3 or 4 1" wide (?) 'bridges' that extend between the inner and outer parts, below the window channel. You could use a bit of sealing mastic if you wanted to. But it won't do much.
- Been thanked: 17 times
i also run a light bead of Mastic to squash between the vertical edge of the lower furry slider channel & the inner vertical of the door frame area as with "repro" slider channels fitted .. i have had rain / wash water run down behind the slider channels in that small but became an issue gap area .
Thank you.
Do you have a part number, a retailer or a picture of these bridges please.
- mab01uk
- Has thanked: 86 times
- Been thanked: 63 times
I think the 'bridges' Peter mentioned are actually part of the door bridging the 'water gutter' below as seen in photo above, which the window slider channel sits on. Those I have removed usually have some kind of mastic below the window slider channel where it sits on the 'bridges' and metalwork below.
Be very careful to use a true mastic…. NOT something adhesive like silicone.
If the sealant is adhesive you’ll never get to replace the runners again …EVER..
Cheers, Ian
Cheers, Ian
Thanks for the info.
I've searched everywhere for that seal cannot find them.
Any suggestions?
Any suggestions?
I do not really understand how you're supposed to seal the chrome part to the door. I had rain water dribbling out between the two. I had to run some CT1 along the edge on the inside.
The sealing mastic I've seen in this spot is very similar to plumber's putty.
Kelley
Kelley
I use the panel mastic from 3M = 08568 none-hardening will not shrink .. comes in 6mm strips ( i have rolled it to become thinner for the window tracks) .. now looking at my box of this stuff it has an expiry date of 2021 .. not an issue with my remaining new unused mastic it is still good to be used... good stuff & even used some on my J40 pedal car.
- Exminiman
- Has thanked: 21 times
- Been thanked: 9 times
Another reason never to use silicon sealant, is it will cause rust due to its acid etch
Thanks for the tip. I'll get some.Polarsilver wrote: ↑Wed Jun 26, 2024 4:29 pm I use the panel mastic from 3M = 08568 none-hardening will not shrink .. comes in 6mm strips ( i have rolled it to become thinner for the window tracks) .. now looking at my box of this stuff it has an expiry date of 2021 .. not an issue with my remaining new unused mastic it is still good to be used... good stuff & even used some on my J40 pedal car.
Good information for the mastic, but I need the rubber seal shown in the photo.
Where can I get these from please
There's no rubber seal. The channel sits on the top of the door,on the bridges. I looked up the mini restoration book mentioned earlier, it does have some very good Haynes type photos.
https://www.somerfordmini.co.uk/haynes- ... ion-manual
They cover the entire area with mastic, Propoer mastic. They also put it on the underneath of the channel to prevent leaks.
