cleaning and soldering copper cables
woodypup59
Been thanked: 13 times
Post by woodypup59 »
I have a bullet which has pulled off a cable (a thin one - for the wipers earth).
Stripping the wire back, the copper has black tarnish and despite attempting clean to bright with abrasive, it won't solder.
Is there a decent acid flux I can use, instead of the 'grease' type flux which doesn't seem to work.
I don't want to use crimps as they look terrible.
Has thanked: 27 times
Been thanked: 29 times
Re: cleaning and soldering copper cables
I use one of the basic acids that you'd find in your kitchen. Bleach and oven cleaner spring to mind. I have used acid based wheel cleaner too. Insert bare end into the acid for, say, 15 seconds and it'll come out like a shiny new pin. Ready to solder.
But make sure that you rinse in a clean water and dry before you start to solder.
woodypup59
Thanks Peter,
Vinegar followed by bicarb worked a treat.
snoopy64
Has thanked: 16 times
Post by snoopy64 »
Ketchup overnight if it’s a bit more delicate/thin ..
Kevin
Joel Welsh 4769VU
Post by Joel Welsh 4769VU »
Barring all of the above-
Ferric chloride will etch, clean, brighten and eat into copper- removing all contamination.
Wauseon, Ohio- United States
Tartan red and black
I can't take credit for what others built- all I can do is try to put her back on the road. :shock:
You just can't fix stupid... you can hide it sometimes though... :lol:
trevorhp
Post by trevorhp »
mk1 wrote: Fri Jun 21, 2024 7:25 am Bakers No3 Soldering fluid.
https://www.amazon.co.uk/Bakers-Solderi ... B00Y3P5JZE
Best ever for this job.
And I prefer brown sauce as an alternative 🙂
KDK 320F
HDK 443E
DJJ 226H
TFD 47G
PKV 375
Having tasted Bakers No3 on more than one occasion, I can confirm that Brown sauce certainly tastes better :lol: :lol:
Stoneface
Post by Stoneface »
Maybe you already are, but if not, use leaded solder and not the lead free stuff
minstix
Post by minstix »
Definitely old fashioned electrical leaded solder, not the sort used for plumbing. 40% lead 60% tin with flux cores is best.
