1071 Engines
1071 S
1071 Engines
Post by 1071 S »
Following on from discussions on another forum...
Did all 1071 engines used the flat fronted (so called?) Formula Junior blocks? Were they all like this or was there a changeover date (number) where the "sculpted" type casting came into use?
Parnell seems conspicuously quiet on this issue.
Cheers, Ian
251 ENG
Re: 1071 Engines
Post by 251 ENG »
The first 1400 - 1600 blocks were the FJ / flat front type , change point in car production is appropriately December 63 to February 64 .
By mid 1965 the AEG 151 blocks had been used up , BMC were supplying cut down AEG 312 casting for 970 / 1071 .
This continued into thick flange block production so a 970 / 1071 with a thick flange block is a period correct replacement.
Exminiman
Has thanked: 21 times
Been thanked: 12 times
Re: 1071 Engines
Post by Exminiman »
251 ENG wrote: Sun Jun 16, 2024 8:39 am This continued into thick flange block production so a 970 / 1071 with a thick flange block is a period correct replacement.
Interesting info, the logical thing for a manufacturer to do…..take a bit of defending at a car show though…..😁
