Fan belt size for Mini Cooper S MK2
minstix
Post by minstix »
Hi,
I'm having a bit of a dilemma regarding the correct length of fan belt for my MK2 Cooper S restoration project. I thought it would be a quite straight forward thing to look at the usual mini parts suppliers websites and find out but it's not that easy. Mine is a standard setup with original pulleys, original (refurbished) C40 dynamo. New water pump though but all pulleys are the original ones.
I understand that the part numbers are, for example, GCB10813 etc where the last three digits are the length in mm.
Cooper S cars had a larger diameter dynamo pulley so it doesn't over rev the dynamo. Mine has the original one. It seems to be about 92mm in diameter going from the very furthest edges across (not inside the V where the belt sits).
I can't find anywhere which clearly says which size I should be fitting on a 1969 Cooper S MK2 with dynamo. I can find references to early 998 cars and later 1275 cars with alternator.
Can anyone point me in the right direction?
Thanks for your help as always,
Steve
floormanager
Re: Fan belt size for Mini Cooper S MK2
Post by floormanager »
I'll check mine in the morning but I believe it's the 813. I know I had a belt on it previously, which was too long.
Has thanked: 59 times
Been thanked: 15 times
floormanager wrote: Mon Jun 10, 2024 8:47 pm I'll check mine in the morning but I believe it's the 813. I know I had a belt on it previously, which was too long.
This is it.
minstix
Post by minstix »
I've tried an 813 but I can't get it over the dynamo pulley, no chance when the dynamo is hard against the engine. The next size up is 838.
I wish I'd kept the one I took off a few years ago when sripping the car down. I think I may have just cut it off and chucked it in the bin back then. I had fitted that one years ago and don't remember struggling. Hmm...
Steve
When you refer here to the pulley;-
minstix wrote: Mon Jun 10, 2024 8:34 pm Cooper S cars had a larger diameter dynamo pulley so it doesn't over rev the dynamo. Mine has the original one. It seems to be about 92mm in diameter going from the very furthest edges across (not inside the V where the belt sits).
Are you meaning it's been fitted with the Special Tuning Pulley C-AEA535 that would normally take the Fan Belt that comes up as Special Tuning C-AEA756 ?
This is a 10A0850 or some may list it as a 850.
NZmember
Post by NZmember »
I just had a similar experience. It was caused by a stud holding the alloy spacer for the engine / rad mount. I filed ~1mm off the end of the stud which then allowed the belt to fit through the gap and sit on the bottom pulley. Difficult to see, but luckily I checked before putting the engine in.
minstix
Post by minstix »
I managed to fit through and get it to sit nicely over the bottom crank pulley and the water pump pulley. It then won't go over the dynamo pulley.
Steve
TECH396
Post by TECH396 »
My 68 S originally came with AEJ101 and a NOS one measures 840mm and is the one for the setup you described, and the one I used on my car with the same setup.
Paul H.
GraemeC
Post by GraemeC »
If you’re unsure, just set the dynamo in the middle of its adjustment and then use a length of string wrapped around the pulleys to measure what’s needed.
minstix
Post by minstix »
The string idea is so simple, why didn't I think of that. Thanks, I'll try with some thick-ish stuso it doesn't go right to the bottom of the V on the pulleys and let you know the results.
I'm not sure how they measure the diameter of the pulleys, maybe not from the furthest edges as I've done. But it seems that the standard size of dynamo pulley that was fitted to a Cooper S MK2 was 75mm wide, part number 12G2102 and is still available new (for about 80 quid, so I'll avoid buying one unless I have to).
I'll let you know how the string works out.
Steve
Has thanked: 27 times
Been thanked: 29 times
Your question was just too ambiguous Minstix. There were just too many variables to cater for. I was going to suggest another way to suit your particular situation........... But Graeme's answer is even simpler than mine!
Where there's a will, there's uusually a simple way - or answer! Thanks Graeme
minstix
Post by minstix »
I've tried Graeme's string idea using thin rope that's about 5mm thick so it doesn't sit right down into the V on the pulleys. With the dynamo mounted and tilted to about the ideal position, which is about half way along adjustment, I pulled the rope reasonably tight and marked it where they met. Then measuring it came out to 340mm.
That's pretty close to the 838 belt that's available, part number GCB10838. That's the next size bigger than the one I originally tried which was the standard GCB10813. The last three digets are the length in mm. So if I order an 838mm belt it should fit. Thanks Graeme for such a simple but affective idea.
Steve
TECH396
Post by TECH396 »
minstix wrote: Tue Jun 11, 2024 3:54 pm I've tried Graeme's string idea using thin rope that's about 5mm thick so it doesn't sit right down into the V on the pulleys. With the dynamo mounted and tilted to about the ideal position, which is about half way along adjustment, I pulled the rope reasonably tight and marked it where they met. Then measuring it came out to 340mm.
Steve
Belts are measured along the length of the outside. You need a 840mm belt as per factory original.
Paul H.
minstix
Post by minstix »
Sorry, it should have read 'measuring came out at 840mm' not 340mm.
Steve
GraemeC
Post by GraemeC »
TECH396 wrote: Tue Jun 11, 2024 5:09 pm
Steve
The AEJ101 you mentioned earlier lists as equivalent to 838mm
TECH396
Post by TECH396 »
GraemeC
[/quote]
Sue me 😂😂😂😂
Paul H.
