Boot Lid
- alexdenevers
Re: Boot Lid
Thanks very much for that!
So....would the lid of early MkI's look the same as a MkIII on the inside? ( knowing the plate indent would be different on the outside)
- Simon776
Re: Boot Lid
Yes, it should.So....would the lid of early MkI's look the same as a MkIII on the inside?
Re: Boot Lid
Rubber cones -> hydrolastic -> rubber cones comes to mind.
Maybe easy access needed to the inner part of the bootlid?
Re: Boot Lid
Sure, I didn't mean to say the bootlid change was connected to the suspension - obviously it isn't.
I just referred the suspension as they were originally rubber cones, then went to hydrolastic and the back to the original rubber cones.
Then I tried to think why would they change the bootlids to the original form, but didn't mean to make the connection to the suspension.
When I said easy access needed I thought of wires, mounting fog lamps, badge clips falling to the inner part of the lid, repairs, etc...
Anyway, maybe even a matter of costs? One less panel to apply?
Re: Boot Lid
I don't know why they changed & then changed back again, but I suspect that it was something like this.
They had the original single skin boot lid which had either a cardboard cover screwed to it or had a mat attached, someone said it would be much cheaper to make a double skinned boot, this way we can save on boards, screws, mats, clips etc. So they produced the double skin boot lid. Thjis became a standard feature across the range but then on the introduction of the MK3 they were looking to cut costs and thought the single skin boot lid is cheaper than the 2 skin version, if we fit these to the car with no mat or boot board it will be even cheaper. So that is what they did.
MOST modifications to the Mini (apart from some of those involving the Cooper S's) were invariably down to saving money.
Re: Boot Lid
Thanks.
OK...bottom line.....,
For a 1962 Morris Deluxe ( unsure of month ), the proper boot lid would be single skin with the older style licence plate indent
- Has thanked: 6 times
Re: Boot Lid
mk1 wrote:I don't know why they changed & then changed back again, but I suspect that it was something like this.
Lol excellent assumption and most probably accurate.
Also i think they may have thought the single skin bootlid was easier to tweak.
You know the tweek I mean when the lid needs a little twist to make it sit half decent in the hole.
Re: Boot Lid
I never went to the factory, but someone who did told me about the GIANT RUBBER "TWEEKING" HAMMERS employed to make stuff fit
