Hi all
I'm in a dilemma if to fit my FB34 clubman spec alloy speedwell head to my 1071s motor or sell it on . ?
would it be a direct fit or at most just abit of fettling to fit ?
any advice on if somebody has fitted one would really help .
cheers
speedwell head for 1071 s
- LarryLebel
Re: speedwell head for 1071 s
I do not have first hand knowledge of these heads but have heard that some can be porous and have other problems that need resolving. I would get it thoroughly checked/tested before considering fitting.
- AndyB72
What letters are stamped near the thermostat? The valve sizes look like they are best suited to small bore rather than larger bore, this would definitely be a step back performance wise, would look great though
The main issues with these heads are corrosion, wrecked rocker pillar stud threads and valve guide issues. If a race cam is used, or the valves jam, the guides can spin/move which causes all sorts of issues and is expensive to repair.
I'd stick it on the shelf and fit it to a 998/1100 in the future. Also worth noting is you'll need an exhaust manifold with round ports, I bought mine from good old Maniflow.
Total waste of time a good Speedwell Clubman flows less well than a standard 295.
While you could fit it to a 1071 without any issues at all. You could also remove a couple of pushrods to get a similar change in performance.
They are a great & very interesting head on a small bore but, useless compared to anything large bore.
This is the Speedwell head you need for a 1071 S
Good one Mark.
Remove a couple pushrods. Needed a chuckle to start the day
