Cooper S servo brake pipes for a dry car
kit of bits
Post by kit of bits »
Hello chaps
Has anyone got some good pictures or even some accurate pipes to help me make some servo brake pipes for a 1275 S dry car?
Thanks Dave.
Polarsilver
Has thanked: 4 times
Been thanked: 18 times
Re: Cooper S servo brake pipes for a dry car
Post by Polarsilver »
Dave .. servo pipe set here you can borrow to copy .
kit of bits
That was easy, thanks Norman..
AndyPen
Been thanked: 22 times
Post by AndyPen »
Polarsilver wrote: Sat Feb 24, 2024 9:23 pm Dave .. servo pipe set here you can borrow to copy .
Brilliant - took me a while to work that out when I did it. Are these the same Norman - from my '64 1071 build up?
kit of bits
Excellent picture thank you Andy
AndyPen
Post by AndyPen »
If you need anything else let me know, I based these on a local '64 1071 that surfaced a few years ago and still had the originals, or at least they looked correct when compared to period pictures.
If you can compare to Norman's that would be great - just to be sure?
kit of bits
AndyPen wrote: Sun Feb 25, 2024 3:15 pm If you need anything else let me know, I based these on a local '64 1071 that surfaced a few years ago and still had the originals, or at least they looked correct when compared to period pictures.
Thanks Andy, Norman is just down the road I’ll have a chat with him soon.
LarryLebel
Post by LarryLebel »
To me, the servo in the picture should be more at an angle.
Exminiman
Has thanked: 21 times
Been thanked: 12 times
Post by Exminiman »
AndyPen wrote: Sun Feb 25, 2024 9:59 am
Sorry to go off on a tangent, but can I ask where you got the wing protectors ?
EDIT….think I have found them http://www.winguards.co.uk/page4.html
Has thanked: 29 times
Been thanked: 30 times
Mmmmmmmm.... I hope someone tells me that I'm wrong here but..... I have a feeling that the servo pipes were directed more over the top of the servo as opposed to along the flitch panel. From the master cyl to the INlet and then out of the outlet, again, over the top of the servo, clipper together with a small two piece clamp held together with a small nut and bolt. One then down to the hydraulic 3-way junction.
Or is that for wet/hydro cars like mine. That said, as shown,looks to be a better method.
AndyPen
Post by AndyPen »
They changed fairly soon after I think Peter, I'm sure someone else can confirm if it was hydro?
Larry, this is the original inner wing apart from the bottom corner where it is welded to the front panel, so it might just be the angle of the pic that is deceptive?
Edit to say that what clinched it for me was the early 1071 pic on here ;-)
Ronnie
Been thanked: 7 times
Post by Ronnie »
Peter Laidler wrote: Sun Feb 25, 2024 9:13 pm Mmmmmmmm.... I hope someone tells me that I'm wrong here but..... I have a feeling that the servo pipes were directed more over the top of the servo as opposed to along the flitch panel. From the master cyl to the INlet and then out of the outlet, again, over the top of the servo, clipper together with a small two piece clamp held together with a small nut and bolt. One then down to the hydraulic 3-way junction.
As you infer Peter there were two different runs one more over the servo. :? I believe it was an Austin / Morris thing, perhaps one of the more well versed members could comment on this subject :?:
360gts
Been thanked: 20 times
Post by 360gts »
From what I can remember...the 1071 had the pipes under the servo and attached to the inner wing....think later 1071's were like the 970/1275.
The 970 and the early 1275 had them over the servo....
Just from memory...could be wrong.
Here is a picture of an early 1275 showing the layout of the engine bay. Think it was the same for both dry and wet cars.
kit of bits
From what I can work out dry car to the side, wet car over the top?
Dave
AndyPen
Post by AndyPen »
Another little tell tale has just come to mind if you have the original inner wing - there will be a screw hole at the top where the pipe fixings go - there is a clamp there to hold them. Checked on the remains of a June 64 dry 970 that I still have and yes, the hole is there. If Bob 1071 comes along, he and I came to the same conclusion, and Bob being Bob he made the clamp in stainless ;-)
Polarsilver
Andy, re your 64 car Austin or Morris ? ..maybe as mentioned the difference with Birmingham or Cowley Servo Pipe runs.
AndyPen
Post by AndyPen »
Mine's a Morris but that's a point as the car I copied was an Austin Norman. Both genuine 1071s to the best of my knowledge. The 970 with a screw hole was an Austin too.
1071bob
Been thanked: 11 times
Post by 1071bob »
I don't think it was an Austin/Morris thing, my car is a Morris and it had the pipes clipped to the inner wing. I'm sure the pipe runs were changed when the hydro came along, there isn't a lot of room to route the pipes the original way with the hydro flexi pipe and bracket under the m/cylinder area.
If you are making your own pipes to the early spec here are the pipe dimensions.
AndyPen
Post by AndyPen »
Thanks Bob, your pics are excellent ;-)
Andrew1967
Post by Andrew1967 »
Certainly the pipes were changed when hydro came in.
This is the layout for an early hydro car, with the 'fresh' air heater pipe stopping at the triangular stiffener, as taken from various original cars and period photos.
