Interesting, potential to be made 4wd, modify it as you like, DVLA have nothing to compare it against
Honey I shrunk our Land Rover!
I had a L reg 73 clubman and the tunnel looked just like that. I think the clubman changed to rod change in late 72.
Agreed……didn’t the square tunnel come in around 74….and the rubber mounted subframe ( single bolt ) around 76. And when did the drip rail disappear ??
Square tunnel doesnt equal single bolt subframe
That GT looks a beauty, and reasonable too, pending a closer look.WMU 211G wrote: ↑Fri Oct 06, 2023 1:12 pm A few that have just caught my eye...
1275GT...
https://www.carandclassic.com/l/C1638843
Clubbie Estate...
https://www.carandclassic.com/l/C1629427
Mk2 S...
https://www.carandclassic.com/l/C1599782
Innocenti 850 which we've seen before...
https://www.carandclassic.com/l/C1604110
The rod change gearbox and the square tunnel arrived in late 1972.nick@dunsdale wrote: ↑Tue Oct 03, 2023 10:15 amso you can have a square tunnel mk3
Yes see what you mean, lets hope its not reflected else where...lots of new bits as well.kit of bits wrote: ↑Fri Oct 06, 2023 7:18 pm 1071, I did start to briefly look at this, then I sore the battery box welding ..
https://www.ebay.co.uk/itm/276083984670 ... edia=EMAIL
