Lucus 11ac alternator
Robbie224
Post by Robbie224 »
Hi has any ever fitted a small lucus 11ac alternator to a A series mini?
m1cH1
Re: Lucus 11ac alternator
Post by m1cH1 »
Whatever it is, the alternator on your pictue is not an Lucas 11AC alternator...
Robbie224
Post by Robbie224 »
OK thanks . They used to use them on the cooper s back in the day . What do they look like?
Ronnie
Has thanked: 12 times
Been thanked: 29 times
Post by Ronnie »
Robbie224 wrote: Sun Jul 02, 2023 8:50 pm OK thanks . They used to use them on the cooper s back in the day . What do they look like?
Wiring diagram neg earth > https://mk1-performance-conversions.co. ... ac-neg.pdf
Positive earth and more under electrical here > https://mk1-performance-conversions.co. ... ection.htm
They were used by Abingdon on the works cars, they use a separate 4TR control unit (regulator) as opposed to an integrated one.
They were standard fitment on a lot of vehicles 60's-70's
https://www.heritagerotating.co.uk/prod ... ternators/
Stopped-again
Post by Stopped-again »
Hi there, the 11ac alternator could not be described as “small”, it’s chunkier than an “acr” alternator. This picture shows the cast alloy bracket that fits it to the block and on “works” cars the front panel was cut away to allow easier fitting and removal.
Robbie224
Post by Robbie224 »
Ah yes. Thanks for clearing that up. Appreciate the image.
Rob
Exminiman
Has thanked: 54 times
Been thanked: 51 times
Post by Exminiman »
I do dont think the 11AC was a “Works” Alternator as such, it was fitted to various vehicles back in the day - inc Vans and lorries.
There are various types as well, inc right and left fitting and neg and pos earth……
As far as I know they all need a separate regulator box as well.
The “Works” may of fitted specific parts though (I am not sure ) like brackets ?
One to be careful buying….
Has thanked: 135 times
Been thanked: 113 times
My cop car had an 11 AC alternator fitted, with seoarate regulator (mounted on right hand side of scuttle panel). I machined the insides of the old 11AC to accept 18ACR guts.
Ronnie
Post by Ronnie »
Exminiman wrote: Mon Jul 03, 2023 6:54 am I do dont think the 11AC was a “Works” Alternator as such, it was fitted to various vehicles back in the day - inc Vans and lorries.
Well let us just say Abingdon fitted 11 AC's :!: This was published in MotorSport April 1966. :shock: It was of course won by Rauno Aaltonen :roll: 8-)
Lucas used the Abingdon works as test beds for theirt alternators for durability and the soaking that they'd be subject to. They did want to use Army mid range vehicles such as Land Rovers (The Bedfords were starting to use the big AC Delco alternators) but seemingly, the MoD didn't want its operational fleet used as guinea pigs.
Exminiman
Post by Exminiman »
Ronnie wrote: Mon Jul 03, 2023 9:59 am
I was not saying that the "Works" didn`t fit them, just that they were also fitted to a number of other vehicles as well - so not a special "Works" only item ...
cpr1
Post by cpr1 »
Any details what was used on Work's cars , positive or negative ground and the reason why?
Thanks Cpr1
Ronnie
Post by Ronnie »
cpr1 wrote: Wed Jul 05, 2023 5:29 pm Any details what was used on Work's cars , positive or negative ground and the reason why?
Thanks Cpr1
Early cars positive ground (because that is the way that they were in production), I suppose they changed to negative earth when it came into production Mk2 possibly :?:
They changed it I believe to do with electron flow & its effects on body corrosion. :?
cpr1
Post by cpr1 »
Is it just a myth or reality that pisitive ground effects corrosion?
Ronnie
Post by Ronnie »
cpr1 wrote: Wed Jul 05, 2023 7:39 pm Is it just a myth or reality that pisitive ground effects corrosion?
I believe there are other benefits spark plug erosion, but I don't think it's a myth but I just go with the Flow so to speak. :D :D ;)
Exminiman
Post by Exminiman »
Peter Laidler wrote: Mon Jul 03, 2023 11:18 am Lucas used the Abingdon works as test beds for theirt alternators for durability and the soaking that they'd be subject to. They did want to use Army mid range vehicles such as Land Rovers (The Bedfords were starting to use the big AC Delco alternators) but seemingly, the MoD didn't want its operational fleet used as guinea pigs.
In mid 60s significant proportion of the BMC vehicles using 11AC as a “Standard part” were commercial, I wonder if it had any thing to do with influence from Leyland ?
They were also using a combination of positive and negative earth….I suppose, it depended on when the model was released.
Polarsilver
Has thanked: 38 times
Been thanked: 52 times
Post by Polarsilver »
my memory from the mid 60,s .. Alternators were seen as not suitable for Cars as the Lucas Alternator were 12v negative earth & they supplied 24v battery packs .. Leyland Industrial Engines ( 6 & 4 cyl: ) that we installed in new built Mobile Cranes all had Lucas Alternators & there was never an issue with reliability.
