Primary gear
diz
Primary gear
Post by diz »
I’ve purchased a NOS primary gear that is identical to my original item except for the metal ring on the seal surface, as pictured. Can anyone confirm the purpose of the ring? I’m guessing it’s an oil deflector, and advise if it’s possible to retrofit a new one or swap the one from my original gear.
Thanks, Diz
GraemeC
Re: Primary gear
Post by GraemeC »
Only looking on my phone, but they don't look identical to me - one seems to have an A+ tooth profile, the other an earlier A-series profile.
If the tooth profiles are different then they aren't interchangeable.
Re: Primary gear
Assuming the tooth profiles are the same, something that needs checking CAREFULLY! You can swap that little thrower ring from 1 to another without too many issues. But if you fit one of these when you assemble, you don't really need to bother.
diz
Re: Primary gear
Post by diz »
Thank you both for your comments, and Graeme, I think you are correct. It was sold to me as pre A-Plus and I had not got as far as checking the mesh with the idler but I've just done so now and there is clearly a difference.
GraemeC
Re: Primary gear
Post by GraemeC »
The flat topped tooth profile is A-series (left hand in the photo), the more pointed profile is A+
Has thanked: 59 times
Been thanked: 15 times
Re: Primary gear
The early primary gears didn't have the Oil Slinger, it was added later (64 or 65-ish off hand). I would advocate fitting one.
As Mark suggested, it can be swapped over, they are pressed on, but just go easy and keep it dead square removing and refitting, they get out of shape easily and not put back in to shape so easily ! Maybe even a few dabs of a retaining compound would be wise.
Easiest way to check for A or A+ if you are unsure is to count the teeth - A has 24, A+ is 29.
diz
Re: Primary gear
Post by diz »
Is this true of a 998/1098? Only both of mine are 24 teeth but, as Graeme has identified, the new gear has a more pointy profile.
Re: Primary gear
Yeap 998, 1098 and 1275
There was economy gears available in A+ that had 30 and 31 teeth to but all A gears were 24 tooth
Exminiman
Has thanked: 21 times
Been thanked: 13 times
Re: Primary gear
Post by Exminiman »
mk1 wrote: Tue Jun 20, 2023 5:05 pm Assuming the tooth profiles are the same, something that needs checking CAREFULLY! You can swap that little thrower ring from 1 to another without too many issues. But if you fit one of these when you assemble, you don't really need to bother.
Thats interesting, are they worth fitting then ?
