Camshafts without fuel pump cam lobe?
Mini4Ever
Post by Mini4Ever »
Have there been standard 848cc camshafts that did not have the cam lobe for driving a mechanical fuel pump? In particular for early engines in cars that had an electric fuel pump.
Too many cars...
Fanfaniracing
Re: Camshafts without fuel pump cam lobe?
Post by Fanfaniracing »
I had a 1961 Morris Traveller with electric Fuel Pump.
I guess it was original.
Also my 1965 Austin Countryman has a Electric one. Will have a look if the Engine has a Hole for a mechanical Pump...
I don't think I have ever seen one.
Fanfaniracing
I think you are correct Mark!
Just checked my 65 and it has a cover plate...
timmy201
Post by timmy201 »
They definitely made blocks without a fuel pump opening.
But the original question of whether the cam was also blank is beyond my knowledge
Mini4Ever
Post by Mini4Ever »
mk1 wrote: Fri Jul 15, 2022 4:16 pm I don't think I have ever seen one.
Me neither, so I guess that didn't exist. One more mystery clarified :D
Too many cars...
And the cams that had a twin screw drive on them, this replaced the fuel pump drive. The second screw drive was for a sump pump on some of the inline racing engines, so original factory 544 cams do turn up in Mini's to this spec.
Sir Clip
Post by Sir Clip »
Here's 1, and it had AEG148 written on the paper it was wrapped in. The news paper was from 1984.
Any use to anyone ;)
