WTH??!?! Have you seen this item on ebay.
- mab01uk
- Has thanked: 73 times
- Been thanked: 59 times
Re: WTH??!?! Have you seen this item on ebay.
Phoenix Clubman Estate..
https://www.ebay.co.uk/itm/125355464456 ... SwNelinjE8
- Exminiman
- Has thanked: 21 times
- Been thanked: 9 times
Could be an interesting hill climb, race car....?mab01uk wrote: ↑Mon Jun 13, 2022 11:27 pm Phoenix Clubman Estate..
- Been thanked: 3 times
I like the integrated arches on that! And I agree it could make a great hillclimber or basis for a car for FMITW.
Not sure what class it would have to run in if you hillclimbed it.
And I bet if you were to put it on the scales it wouldn't be much lighter than a steel car.
Still, an interesting thing though.
Your bet would be right Mark , pretty sure I’ve read the GRP minis built in Chile and Venezuela were actually heavier than a steel bodied car , with very thick panels .And I bet if you were to put it on the scales it wouldn't be much lighter than a steel car.
That (optimistically priced) Phoenix used to be mine. I ran it as a daily for about three years with a 1071 motor.
It weighs pretty much the same as a normal mini and the fibreglass quality is not great! It's also quite bendy, if you jack it up on either subframe the doors won't shut/open.
I absolutely loved it though, had to drastically thin out the fleet last year so I sold it to a mate for £300 - not the guy selling it now.
Probably surfing.
Cornwall, UK.
Cornwall, UK.
- Toby
I've had chrome ones too. However they weren't intended for the mini but Hornet or Elf from what I've gathered. This one is quite bent thoughExminiman wrote: ↑Mon Jun 06, 2022 12:23 pm Thought early gearsticks were not Chromed, or until 64 ?
https://www.ebay.co.uk/itm/255537580434 ... SwOkFigWGT
- mab01uk
Mini bodyshell with V5c:-
https://www.ebay.co.uk/itm/125377267974
- Exminiman
Re: Re:https://www.ebay.co.uk/itm/284876329521?hash=item4253f3d231:g:q9oAAOSwPGlivARj WTH??!?! Have you seen this item o
Do like that, would have to re-finish a few things and "De-Bling" the engine bay...colour combo and wheels..look good
- WMU 211G
- Has thanked: 4 times
Tidy '74 Innocenti Cooper, needs work though....
https://www.ebay.co.uk/itm/165555459162 ... SwCMBivdfX
Quite local to me, if I had the space I'd be on it.
1968 Mk2 Morris Cooper
1992 Maserati Biturbo 430 2.8 litre V6
2014 Fiat Abarth 595 Anniversario
That looks a bargain. It is a German market car with non-opening door quarters and the special type arches. If anyone goes to see it make sure you check the chassis number is stamped on the right-side inner wing.WMU 211G wrote: ↑Fri Jul 01, 2022 2:25 pm Tidy '74 Innocenti Cooper, needs work though....
- WMU 211G
I'm very tempted Stu but I've run out of room now! Always fancied an Inno.surfblue63 wrote: ↑Fri Jul 01, 2022 3:25 pmThat looks a bargain. It is a German market car with non-opening door quarters and the special type arches. If anyone goes to see it make sure you check the chassis number is stamped on the right-side inner wing.WMU 211G wrote: ↑Fri Jul 01, 2022 2:25 pm Tidy '74 Innocenti Cooper, needs work though....
- snoopy64
- Has thanked: 15 times
Oooh good spot Nidge, I’d be asking you to take a look if I had space…WMU 211G wrote: ↑Fri Jul 01, 2022 2:25 pm Tidy '74 Innocenti Cooper, needs work though....
Kevin
Kevin
- WMU 211G
Make the space pronto and I'll go and have a shuftie mate!!snoopy64 wrote: ↑Sat Jul 02, 2022 2:31 pmOooh good spot Nidge, I’d be asking you to take a look if I had space…WMU 211G wrote: ↑Fri Jul 01, 2022 2:25 pm Tidy '74 Innocenti Cooper, needs work though....
I rather fancy this already modified '65 Mk1 too, might seem a bit pricey but it's exactly the sort of thing I'd like to do using a Mk1 as a blank canvas...
https://www.carandclassic.com/car/C1466892
(I'd rather pick a mid period Mk1 to start with than a '59 or '60 etc)
